SOURCE: Reloading XP2
MEMORY PROBLEMS Hi, FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! POWER SUPPLY try replacing both your hard disk and / or power supply ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
SOURCE: how to remove the virus Trojan.AVkiller in window XP profesional
Try running an online scan with the following site:
http://www.trendsecure.com/portal/en-US/tools/security_tools/housecall
Click on "Launch HouseCall"
Good Luck!
SOURCE: removing windows xp without formating the harddisk
Go to.
Control Panel > System > Advanced > Start Up and Recovery > Settings. near the top of the window you will see Default operating system, just select the one you want to stat first and delete the other.
SOURCE: Installing Linux
you can use virtual drive to install linux within windows os. you can download virtual drive for free look for virtual box version.
SOURCE: system not booting
plz set ur hardisk as the 1st boot device in the bios setup. u can enter the bios setup by pressing the del or f2 key when u power on the mission
