Question about KitchenAid KSSS36QK Side by Side Refrigerator
Hello. I have a kitchenaid KSSS36QBX00 refr. It looses power once in a while. There is an on/off switch on the front top of the unit. if i turn it off then on the refr powers up and all if fine. Can this be a bad switch or is there something else putting into this state?
  • 403 Answers
Could be a bad switch, I have actually encountered this problem with this refrigerator several times. Just examine the switch and make sure it isn't burned
Posted on Mar 31, 2011
I have the older waterpik. In an attempt to change my hose, I took the unit apart. After changing the hose, I cannot seem to turn the unit on...it appears the the on/off switch is locked.
I just ran into the same problem after disassembling my waterpik. I have a problem with the device not pumping water once powered on. It siphons just fine with power off, so I'm puzzled as to why it quit working 1 use after not using it for a long time.
I finally solved the switch problem at least: Before you attempt reassembling the top to the base, gently pry the switch cap prongs inwards until the cap pops loose. THEN assemble the top and base. Once done, align the switch cap with the internal plastic slide that activates the switch, and pop the cap into place. That should solve the issue.
Sep 13, 2011 | Water Pik Pik WP 60W Oral Cleaning System
The latch on my kitchenaid dishwasher is loose or broken and I can't open the door. Any ideas. Model #KUDS24SE
yes remove the top of machine and make sure the power is switcht off.;;;;;on the front of machine with your hand pushed down to the door switch ,not easy but keep trying,you will find the door switch with both hands wrigle until the door opens i know its hard and your hand will suffer but it will open keep trying,this switch needs replaced at all costs,you might have to replace the switch plus the holder .Once door is open unscrew the two screws and the whole latch will be in your hands remove the plug and you will have it in your hand ,replace backwards to what ive said,good luck psthis part/sshould cost 20 dollers.
Dec 04, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
I have a KitchenAid refr. mod. KSRL25FRSS00 it is turned down to the lowest setting and still freezes things in vegetable box. (new control board?)
Is your milk or eggs freezing? All the cooling in the refrig and freezer spaces is done in the freezer. Sometimes, the control labeled freezer temp controls a vent between the freezer and ref space, allowing air into the ref side. the other control determines run time. try turning thefrz setting up to raise the ref temp.
Nov 15, 2010 | KitchenAid Refrigerators
I cannot change cycles and the dishwasher won't turn on.
Micro controller problem. Take help from authorized service center help.
Apr 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen aid KECC507GBL3 electric 36in cooktop. Burner switch is out - cannot get glass top off. Have removed all screws from plate mountings on the sides. Is there a trick to this?
If it’s a range, there is usually a couple of screws that hold the front of the top down, remove the screws, lift the front of the top and pull it out from the back hinges. Install the new top, make sure there are no loose wiring.
If it’s a cook top then make sure that the power to the cook top has been turned off, open the cabinet and look up. There should be a couple of brackets that secure the cook top. Remove the brackets, carefully lift the top and set it on the counter top (put a towel on the counter top first). replace the glass top (make sure there is no loose or exposed wiring), set the cook top back in the counter, secure it with brackets as was before, and double check your work.
Thanks for contacting fixya.com
Jan 14, 2010 | KitchenAid Cooktops
Kenmore 70 Series washer need to know how to remove top cover to get to drum. Getting rust stains from water dripping from the top panel. Any help would be appreciated. Model#11026722690.
Get yourself a screwdriver Philips.
Now there are two screws either at the front lower of the electrical switches or in the very back of the washer around the same panel.
Unscrew those screws and once they are loose then you should be able to pull the entire top electrical piece towards you.
Once you have this loose then get a flat headed screwdriver and pop out the two brackets that are attached to the top of the unit, under the controller peice you just removed
Next make sure to unplug the wire that is attached to the lid switch.
Once those are loose then you just simply pull the entire cover towards yourself and then you will have access to the area you want to be in.
Good Luck!
Nov 05, 2009 | Kenmore Washing Machines
3 yr old kitchenaid side by side freezer is cold but fridge is only half cold Yhere was some ice buildup in the middle vent so I unplugged for about 5 hours then plugged back in and the next day same...
Sounds like the defrost timer is not working. There is an approx. 1/2 inch white round shaft with a hole in the middle somewhere either inside the refr. section or on the front bottom frame. If you stick a screwdriver in it and turn it clockwise until it clicks, the compressor will shut off and go into defrost. If it doesn't come on after about an hour, then turn it until it starts. Mark it to see if it turns. It should do one rotation either every day or twice a day. If it's not turning you need a new timer. Cheap and easy.
Aug 02, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Kitchenaid kawe577bwh1 front load washer will not spin
Sounds like the timer might be defective. Try turning the timer manually to see if it goes into spin cycle. If it does then thats what it is. Hoped this helped if not let us know thankyou!
Mar 16, 2009 | KitchenAid KAWS850L Top Load Washer
I am not getting power to the heating elements.
Maybe you should first by checking the fuse to the unit.Look around where the power cord come into the unit.The fuse may be blown.
Mar 15, 2009 | KitchenAid KHHS179LSS Convection /...
KitchenAid KSSS36QK Side by Side Refrigerator Logo
77 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
