Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Leaking water from under the freezer side - Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
  • Amana Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
Water comes out from under the refrigerator every three or four days. I checked everything under. The water hose is find no leaks. The water tray under is empty. Is not a large amount of water maybe...
I dont know if you have a side by side or the freezer is on top,but thats a fairly common thing and the following is what i already wrote before what to check when it leaks like your experiencing.
SIDE BY SIDE
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
FREEZER ON TOP
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
I hope this will hepl you to fix that leak,
GENE
Aug 17, 2011 | Refrigerators
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
Refrigerator leaking water from freezer compartment, freezing along walls of freezer, but running water out under door
Sounds like the defrost water drain is plugged up. It could be a piece of food wrapper fell into it, or something. What make and model is it? Top freezer? Side by Side?
Dec 30, 2009 | Refrigerators
Water leaking under freezer side
Hi, is the leak coming from the hinge on the freezer door? Do you have ice building up inside the freezer section?
Please let me know
Vic
May 31, 2009 | Refrigerators
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
Aug 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
43 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
