Question about Panasonic AG-HVX200 Mini DV Digital Camcorder
I always shoot in 720/24pn i will shometimes shoot in 60 frames but mostly always 24 frames. when i go to log and transfer in fincal cut a chosen few clips are in 12 frames. i never changed it to that. and i never know what ones it will be. its so random. but obviously unusable to be. i need to solve this.
  • 58 Answers
Try a factory reset and see if same differences.If same try a firmware upgrade.
Posted on Mar 31, 2011
My minolta maxxum htsi has recently been cutting the negative in half any idea or suggestion to fix this ruined quite a few frames
Are these pictures being taken with flash ? If so, it could be that you are using too high a shutter speed for the entire frame to be exposed. Most cameras have a flash setting, usually around 1/150 to 1/200 second, and if you use a faster speed the shutter closes before the frame is fully exposed.
May 03, 2016 | Minolta Photography
Tip
Final Cut Pro X Review-No Log and Capture or Log and Transfer?
The newly released Final Cut Pro X is now a hot topic, especially among the FCP 7 or 6 users. The UI of FCP X is different from the older versions. The style change is somewhat like how Adobe Premiere Pro CS4 differs from the older versions. In the other words, it is from grey to black. Of course, Adobe Premiere Pro is different form FCP. <br /><br /><b>How would FCP X change the video editing on Mac?</b> <br /><br /><b>- No Log and Capture , Log and Transfer</b>: <br />With FCP 7 or below, the Log and Capture option is to import tape-based videos, while the Log and Transfer option is for file-based camcorder videos. If you have mini-dv like Sony HDR-FX1S, you may need another tool to capture and save videos as a file, and then import to FCPX. <br /><br />For videos from file-based camcorders, the process is like working with iMovie. The Camera Import window should pop up when camera is connected to Mac for you to select clips. Then click Import Selected, or the like button to load videos. Even though FCP X is supposed to import AVCHD files in .mts or .m2ts format, there are still users reporting the problem. If that is the case for you, you may need to transcode AVCHD to QuickTime MOV for FCP. Aunsoft <b><a href="http://www.aunsoft.com/final-mate-mac/">Final Mate for Mac</a></b> would help you make the videos compatible to FCP X. <br /><br />If you use Canon XF100 to shoot videos in .mxf format, or other camcorders with MXF files, just try Aunsoft <b><a href="http://www.aunsoft.com/video-converter-mac/">Video Converter for Mac</a></b> to see if it works for your .mxf video footage. <br /> <br /><b>- <a href="http://www.aunsoft.com/news/final_cut_pro_x_review_-_no_log_and_capture_or_log_and_transfer.html">No transcoding to ProRes</a></b>: <br />As it is known that the videos imported via Log and Transfer would be transcoded to Apple ProRes. User should wait for the transcoding before editing. It is said that Final Cut Pro X would grant you access to your material right away, saving a lot of time. <br /><br />Actually, there is also timeline for <b>editing in FCP X</b>. But the layout is different from the previous versions. The audio would be snapped to the video. You may find out more interesting features and get used to it.
on Jul 15, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Can't find night mode
You can't find a night mode on the EX-Z40, because it is not there. This nice point and shoot camera does most of the things automatic and has little extra menu's like sport or night shots. And with a max of 400 iso, it will be difficult to shoot without flash in the dark. Although you can switch of the flash.
On the bottom site of the rail with the set knob in the centre you can chose the flash mode when in the rec mode. Then you can cycle trough the flash menu. Giving you automatic, off, always on or red eye reduction. Look on the top of the screen to see what you have chosen.
Oct 28, 2013 | Casio Exilim EX-Z40 Digital Camera
Why does my frigidaire fdb510 run for 2 hours
Hello mrsdear77 - The cycle times all depend on the settings chosen. The hotter the water temperature, the longer the cycle. If you add any other features or a delayed start action, this will also make the unit run anywhere from 60-90+ minutes. What settings do you use the most?
Jan 10, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
WHAT IS THE DIFFERENCE BETWEEN 1080I AND 1080P AND WHICH ONE IS BETTER?
1080i vs 1080p - Similarities and Differences Between 1080i and 1080p
How 1080i and 1080p Are Both The Same and Different
1080i and 1080p are both High Definition display formats for HDTVs. 1080i and 1080p signals actually contain the same information. Both 1080i and 1080p represent a 1920x1080 pixel resolution (1,920 pixels across the screen by 1,080 pixels down the screen). The difference between 1080i and 1080p is in the way the signal is sent from a source component or displayed on an HDTV screen. In 1080i each frame of video is sent or displayed in alternative fields. The fields in 1080i are composed of 540 rows of pixels or lines of pixels running from the top to the bottom of the screen, with the odd fields displayed first and the even fields displayed second. Together, both fields create a full frame, made up of all 1,080 pixel rows or lines, every 30th of a second.
In 1080p, each frame of video is sent or displayed progressively. This means that both the odd and even fields (all 1,080 pixel rows or pixel lines) that make up the full frame are displayed together. This results in a smoother looking image, with less motion artifacts and jagged edges.
Differences Within 1080p 1080p can also be displayed (Depending on the video processing used) as a 1080p/60 (Most common), 1080p/30, or in 1080p/24 formats. 1080p/60 is essentially the same frame repeated twice every 30th of a second. (Enhanced video frame rate.) 1080p/30 is the same frame displayed once every 30th of a second. (Standard live or recorded video frame rate.) 1080p/24 is the same frame displayed every 24th of a second (Standard motion picture film frame rate.)
For more detalis visit http://hometheater.about.com/od/televisionbasics/qt/1080ivs1080p.htm
Oct 09, 2010 | Vizio VP322 32 in. Plasma TV
Playback problems - timer stays at zero
Firewire transfer problem with PV-GS320. HAd bought the PV-GS90 and ran into significant transfer issues importing to Mac (iMovie and Fincal Cut Express HD both had problems). Upgraded to GS320 as Macworld rated it highly. Same problems: video plays back perfectly with no computer connection. once connected, video and audio stutter, go out of sync, sometimes just stop and/or crash the program.
I've used a borrowed Canon GL with this Mac before with no issues, so I suspect the camera. Have tried reset button, trashing preferences, restarts, the works. still can't get clean video to transfer from a brand new camera. Any Ideas?
Feb 09, 2008 | Panasonic PV-GS320 Camcorder
Any movement recorded in HD mode is not clear.
HD mode images may appear to move somewhat stiffly compared with SD mode or DV mode images. This is because they are shot at a rate of 30 frames per second compared with the 60 frames per second for the SD or DV mode images. The movie is shot at 24 frames per second, and looks good. So HD mode can have the same feel as a movie material. For smooth movement during video clips, we recommend you minimize rapid-panning or avoid shooting fast-moving subjects. Should you wish to record more natural motion in the picture, we recommend setting a slower shutter speed, or changing the recording mode to SD or DV.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Sequential shooting modes
There are four modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the DRIVE mode menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Panasonic AG-HVX200 Mini DV Digital Camcorder Logo
63 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
