Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
I have a Robinair 347002K abnd cannot access anything under defaults. Defaults show as a menu item, but I can not see or select anything else under that heading I tried the 5454 password i saw on another post, but it did nothing.
    President:
  • 180 Answers
You may did not try in the right way! The access code (5454) is 100% right for 347002K/347112K and 34700Z new series machines. If keypad has oil injection button (old series machine) press 8787 on keypad.
However you can try as following: To access the change Defaults menu press 5454 (If keypad has oil injection button old series machine press 8787) on the keypad then press ENTER/START arrow key. Now display will change to "Calibrate Scale". Press up or down key to select option you wish to access from: Set Tank Tare, Output Test, Input Test, Keypad Test. Prepare to Ship. Reset Board Memory etc...
NOTE: DO NOT CHANGE 'SET TANK TARE' OR PRESS 'PREAPARE TO SHIP' & RESET BOARD MEMORY' IF YOU ARE NOT FAMILIAR WITH THIS MACHIN!
Hope this will help you. Good luck!
Posted on Mar 31, 2011
Reset hp 1515n
? Restore defaults-used to reset all customer-accessible menu settings back to the factory default
settings (except language) via the control panel or software
NOTE: This service menu item does not reset factory-settable settings, including formatter
number, page counts, factory paper settings, language, and so on.
NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the
information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before
restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset.
Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
1. Press OK to open the menus.
2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select).
3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK.
The product automatically restarts.
Jul 13, 2011 | HP LaserJet CP1515n Printer
UNIDAD DE ALTA PRESION DESABILITADA ROBINAIR
This is a common problem of Robinair 34700Z / 347002k
Sep 28, 2010 | Robinair Cool Tech 34700Z Recovery,...
Machine says pressure exist unable to vacuum system down
It's not clear that you machine is doing recover or not! If the machine is doing recover theh follow the bellow steps.This is a common problem of Robinair 34700Z / 347002k
Sep 16, 2010 | Robinair Cool Tech 34700Z Recovery,...
High pressure unit disable
Aug 31, 2010 | Robinair Cool Tech 34700Z Recovery,...
AT MACHINE TURN ON DISPLAYS UNDER HIGH PRESSURE AND DISPLAY SAYS TO RESET WITH MAIN MENU BUTTON.BUT WILL NOT RESET
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just check the following :- 1# Verify the ISV tank is not overfilled.if full,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid & High pressure switch for proper operation.Hope this will solve your problem, Best of luck & vote for my solution!
Jul 12, 2010 | Robinair Cool Tech 34700Z Recovery,...
ROBINAIR 347002K WON'T INJECT OIL
I think you'v try to inject the oil from ''WRONG'' side,as you say RECOVER/VACUUM which is LOW side manifold valve. You should inject the oil from HIGH side ( Turn the high side valve to CHARGE/OIL INJECT after vacuuming & low side vulv to CLOSE possition ) with pressing F1 key. once you press it then hold the key as long as you wish to inject the oil. If you try this way & you still have problem with oil injection then you may need to check oil injection CHECK VALVE or oil injection SOLENOID ( Both located under Hidg side panel mountin valve). NOTE: UV Dye is not a problem for oil injection! I hope this will help you to solve the problem,Good luck. Don't forge to vote for my solution!
Jul 10, 2010 | Robinair Cool Tech 34700Z Recovery,...
Hi i need to know how to calibrate robinair 347000z mechine
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.Hope this will solve your problem.
NOTE:you should have 9KG/20LBS of weight for scale calibration
May 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
My tom tom says no gps signal for the last two weeks. How do I fix this.
Did anything change in your environment (new car?) two weeks ago?
What happened immediately before you lost signal?
Is everything else working okay on the unit?
Have you updated everything with Tom Tom Home?
Have you tried resetting the unit (paperclip in the small hole on the bottom of the navigator)?
Have you tried resetting factory defaults? (Menu item under Change Preferences; you need to Show All Menu Items to see this one.)
BTW, nobody's satellite got hit by anything.
Nov 21, 2009 | Tomtom ONE GPS Receiver
How do you calibrate a new internal scale in a modle 347002k/replaced scale now I need to calibrate it before putting machine back in service.
From the main menu go to change default option,press 5454 then press enter key.after access to default nenu you have to select calibrate scal option.press again enter key then follow the on scree message.NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.once you done so,press stop key to complete the prcess.
Jul 16, 2009 | Robinair Cool Tech 34700Z Recovery,...
Help
To change the favorite menu to something that you want it to have instead of defaults:
1.)Click on the favorites menu, when a certain item is highlighted
2.)Click on options
3.) select change or remove,
4.Then select the item you want as the default
Best regards,
Priscilla N
Apr 23, 2008 | LG Shine KE970 Cellular Phone
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
708 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
