Question about Kenmore Refrigerators
I cleaned my kenmorefridge sprayed the inside and wiped dry. plugged it in. it worked for 10 hours and quite is there a reset button somewhere i checked all the breakers
  • 132 Answers
The defrost timer may have stopped half way through the cycle.
This will stop the fridge from cooling. Does the interior light still come on?
If it does then a new defrost timer will fix the problem
Posted on Apr 01, 2011
How to use self cleaning oven?
  1. Remove oven racks and soak them in soapy water.
  2. Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  3. 3 Let the oven do its work;it will heat for several hours, charring off baked-on .foods
  4. Fast Cleaning
  5. 1 Remove oven racks and place them in soapy water to soak.
  6. 2 Preheat oven to 200 degrees.
  7. 3 Turn the oven off and spray the inside with oven cleaner.
  8. 4 Allow to sit for 10 minutes.
  9. 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  10. 6 Dry with a soft cloth.
rate this if it help
Thanks.
Oct 15, 2010 | Microwave Ovens
Delonghi CT200 cleaning
hello,
Here are step of cleaning oven
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thanks.
    Oct 10, 2010 | Ovens
    I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
    hello,
    Here are solution on how to clean up your oven below.
    Self Cleaning
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    How to clean laptop screen
    The best way I find it is to use a screen wiper. If you dont have one you can try to use still water and make a paper towel (kitchen towel) humid.. Do not make it to wet that would cause drops to fall on the screen and then with a dry one clean it over.
    If you find your screen is not clean you can use steam from your own mouth.. like you would be cleaning you own eye glasses. I find it quite useful. Then with a dry paper towel clean it in circular movement.
    Hope this helps
    Oct 05, 2010 | Computers & Internet
    How to clean a ge spectra electra xl44 series stove. Just slide door lever from left to right, and turn oven to clean, and forget about it. ???? anything else to do ? Nothing to spray inside oven...
      Self Cleaning
    3. Let the oven do its work; it will heat for several hours, charring off baked-on foods
    4. Fast Cleaning
    Sep 16, 2010 | Kitchen Ranges
    How do I clean oven
    Hi
    These are the things you will need to clean your oven.
    Oven Cleaner, Soft Rags, Sponges, Oven Cleaner and a Sponges.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7mMYimF
    Thanks.
  • Step 4 Allow to sit for 10 minutes.
  • Step 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • Step 6 Dry with a soft cloth.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lkil29
  • Step 3 Turn the oven off and spray the inside with oven cleaner.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lanRHk
    Jul 30, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Buttons doesn't work!
    Do you clean the controls often with a spray cleaner? If so, the face has to be removed and the whole unit inside should be wiped down with denatured alcohol, then dried well. If that solves your problem then start spraying the cleaner on a cloth FIRST, then wipe the unit clean.
    Aug 13, 2009 | Microwave Ovens
    What does E1 mean on the led?
    E-1 Ok i just fixed my HWR 08 XC___ these things should work on most all touch panel models. Note some slight skills required. Ok 08= 8,000 btu 06= 6,000btu exct "size"Ok Code E-1 = electrical problem "yes"
    Mine first started had to be set low and read a lower temp than the room "coils dirty" then week later it showed E-1 and an hour later would trip the plug breaker. Root cause Dirty Coils "evaporator inside" can get ice from reduced air flow making ice n water n throwing drips. when to much of it floods electronics box and faults main to E-1. -drain clean and use remote. ok now to fix other stuff "unplug" remove filter and front cover 2 screws side 2 under filter. Do coils look cruddy ok, sprayed my coils with "gunk engine cleaner" with unit on side so electrics were up and rinsed with thumb over hose for fan spray from two feet away,now though you must first remove the snap in control panel "squeeze tabs and then its metal mount cover for its internal plug 2 screws one is in foam seal then lift and pivot."has tabs" don't wet the electrics or the plug breaker " "see the silver cans in the electric box"capacitors they hold a high voltage charge" stay away. Ok now clean and spray off the rear outside coils. then when done, tilt and and then u must even flip it over till all water is out, "Yeup i got wet too"..now dry electrics for an hour with hair dryer on low and then dry control panel back side on low 15 mins, now exercise touch buttons gently then dry them again. air dry assembled unit a day in sun to be safe
    The cause of this "not so fun project" is plain old dirt and water build up a shure sign of this is unit seems to vibrate more or rumble "crud on one side of fans from stopping in puddle when unit is off and drain is clogged or unit not level or slops to inside.
    Now with every thing dry, use a ground fault outlet first to test how dry you got it, and have a Firemen and a Paramedic helping you...Now hold the on button and plug it in. "good luck" if no go try any units remote most are quite similar...PS remember the E-1 unit most likely still works fine
    allguru
    Jun 24, 2009 | Haier Heating & Cooling
    1992 300e i sprayed dry wire but car still will not start
    Spraying that stuff generally does not work. Remove each wire one at a time and wipe down with as clean dry rag. Then with another rag soaked in either silicone spray or wd40, wipe it down again and replace it. Also...check the inside of cap and rotor for any moisture or carbon tracking. If tracking, replace. If wet, dry it out and replace it.
    Dec 23, 2008 | Mercedes-Benz 300-Class Cars & Trucks
    Refrigerators Logo
    Top Kenmore Refrigerators Experts
    John Tripp
    John Tripp
    minguy15
    Level 1 Expert
    mike cooper
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
