Question about Electrolux EI23BC51IS
I got new replacement doors for my fridge and now when I close the doors the lights wont shut off. this is my second set. The original door lights worked fine. what is wrong?
  • 132 Answers
The original doors contained a hidden trigger that turned the lights off.
You need to retrieve this trigger from the old doors and fit it to the new doors
Posted on Apr 01, 2011
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Tip
How to tell if you need a new fridge seal?
So, you'r wondering, "Do I need a new Door Seal on my Fridge?" Well one simple, and foolproof method, is to use a large Torch, turn the Torch on, and place in middle shelf, of the fridge, facing OUT, now, Close the Door, (It may be best to do this at night actually), Now, have a look for any light escaping, around the door, anywhere you see the light, is an area where the cold, gets out. Sometimes you can see if manipulating the Fridge Door Seal & Magnet, at those Areas, and sometimes you can get small areas to close up, but if you have any big areas, or many, many, small areas, then it is time to Replace that Door seal For sure. There should actually be NO Light at all. The door seal should seal 100%, if not, then as related, the Door Seal, must/should be replaced.
on May 24, 2010 | Refrigerators
Light stays on
Check the door frame for a protruding small lever that gets pushed down when the door closes. If one is visible, that should be the light switch, which probably went bad and needs to be replaced. Without a model # hard to say how the light are set to go off, but most use the above method, hope this helps.
Jan 30, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Neff fridge door doesn't close all the way
Perhaps your refrigerator is not level.
Jul 14, 2017 | Neff Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
The alarm beeper keeps beeping even though the doors are closed. The fridge has been sitting for about a year.
hi,
you can check a limit switch at its door. it is located usually at the door area inside.
maybe it is not working already or get stuck that is why it doesn't sense that the door is closed.
most of the time it is getting stuck and you can fix it by just pulling it out or other ways to do it.
hope that solves your problem.
Don't forget to rate me. Thanks...
Regards,
John
Jan 10, 2011 | Samsung RB215LASH
Wont start are do nothing wont come on but light inside stay on all the time even when door close
Sounds like your door switch needs to be replaced. When the door is closed it is supposed to shut off power to your light, and send a signal to the timer that the dryer is ready to start. If your light is on with the door shut, then it won't start. Pretty simple replacement that you should be able to do yourself. Good Luck, Appliance Specialists
Dec 08, 2010 | Dryers
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Whirpool dryer wont run
inside light on when door is closed??? that sounds like a bad door switch. it doesnt recognize the door shut so it wont start, replace the door switch
Mar 29, 2008 | Dryers
Short in freezer?
IF THE WIRES SHORTED, AND THE DOOR WAS REPLACED,
WAS IT COMPLETE OR WAS THE DISPENSER ASSEMBLY TRANSFERRED TO THE NEW DOOR? IF THE ASSEMBLY ISN'T NEW, THE CONTROL BOARD IN THE ASSEMBLY MAY HAVE BEEN DAMAGED FROM THE WIRE SHORT.
Feb 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Electrolux EI23BC51IS Logo
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
