Question about HP Officejet Pro L7680 All-In-One Printer
My HP L7680 purchased in 2007 is not feeding documents any more. That included the scan as well as the fax mode. Can you help
  • 2,574 Answers
Try this:
Without turning off your printer, unplug the power cable from the unit, after you have done that, on your printer, hold the Ok and cancel button together and while you are holding it down, plug the power cord back and keep holding the buttons for about 5 sec.Once the unit turns off, use the power button and turn it on. the unit would print and alignment sheet and this should fix the issue.
Please check out the official support article from HP regarding the issue you are having with your printer model, as follows:
click here!
Posted on Mar 31, 2011
I want to set up the fax facility of the HP L7680. I have a ADSL modem and share the telephone line. Can you help me? Allen Versteeg
Hi
First you must have a two prong cable (RJ11)
That should be connected to Line 1 at the back of the printer
On the printer press the setup button
Select Basic fax setup >> Ok >>Select rings to answer >> make it to 2
Then Go back to the previous menu select Advanced fax setup>> ok>>
Select Answer rings pattern>> All rings
This should work
For more help you can refer to this following document:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458259&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=2512009
To check if your fax is working fine you can use the following document: (this will help you testing your fax)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00259105&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=2512009
Aug 24, 2011 | HP Officejet Pro L7680 All-In-One Printer
When using scan feature in my HP 7680 printer any document I scan never scans to its original size, it always shrinks by at least 30%; how can I scan documents to original size?
Try checking your setting. press scan menu (over by the fax buttons) then choose paper size. you may have it on a smaller size. i have mine on automatic. See if that works.
Aug 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP L7680 All-in-One will not scan or fax
connect the phone line in printer and set the parameter like auto answer and sending and receving mode also install the scanner driver .just reinstall the printer driver it will installl the missing components.
Dec 18, 2009 | HP Officejet Pro L7680 All-In-One Printer
I use Adobe Standard 9 to scan documents for archive. When I scan from the glass it works just fine. When I scan multiple pages from the document feeder, I get errors. I've updated my hp software for the...
Hi! I will be glad to assist you in this issue, here is the solution that will help:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01537611&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
Nov 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Jul 08, 2009 | Office Equipment & Supplies
Can I scan multiple pages by using the document handler on the HP L7680 Inkjet All-in-One Printer?
Yes, you can do this by knocking together the sheets you want to scan into a small, lined-up stack and then put them face up, in the ADF loader.
Bear in mind it can only handle so many sheets at a time (think it's 15?) so don't stuff it with too much or it'll choke.
Remember also that it needs nice straight edges, not dog-eared bits of scrap paper otherwise it'll mis-feed or crumple your source documents.
Oh and you'll need to make sure the software you're using can actually make use of the ADF... The HP provided software can, but it may take a little bit of experimentation to figure out the best, most-appropriate settings.
Hope that helps..
Martin
Mar 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
Fax wont work
HI,
here is the document that i want you to follow. On this document, just go gown further and STEP FOUR: OPEN THE TOP COVER AND CLEAR THE JAM.
CLiCK HERE TO GET THE DOCUMENT ==> DOCUMENT
Please let me know the outcome after following the document.
Thank you so much.
adonscott
Jul 16, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
