Question about HP LaserJet 4100n Printer
4100N printer, configured OK and can print from any computer on the network with one exception: our unix based business system. Our business system vendor says the printer does not accept post script data (?) and may require a new server card. Sounds good except the card they want to sell is the same as the card that is in it. How do I know if the printer is post script compatible or not ? Can I restore it or program it to such a state ? We have 3 other 4100 printers on the network and have zero issues.
  • rgrapsy Apr 01, 2011
    There is no problem with connecting from individual PCs on the network. The mainframe cannot print to the printer because the network card does not support post scripts. How do I program the network card in the printer to be post script compatible ? The mainframe currently does print to 3 other 4100 printers on the network without issue so the problem can not be with the main frame computer.
    Genius:
  • 1,570 Answers
Hi
Try to download a postscript printer driver for your HP laserjet 4100 printer and install it to your computer. Then set up again the printer. Here is the link http://downloadnew.org/drivers/printer/hp-laserjet-41004100-mfp-postscript-driver-download-245610.html#dlink.
It hope it helps you. Regards
Posted on Mar 31, 2011
  • 1 more comment
  • Benjamin Jr Singson Mar 31, 2011
    Or if still not working with the 1st solution. Follow this steps.
    Before proceeding with the software installation, the printer must first be properly set up, and your computer must be ready to print.
    * Turn on the printer first, then turn on the computer.
    * Close any screen savers, virus protection programs, or other software programs running on your computer.
    * Click on Download Now and a File Download box will appear.
    * Select Save This Program to Disk and a Save As box will appear.
    * Select a directory to save the file in and click Save.
    * Locate the file using Windows Explorer when the download has completed.
    * Double click on the file. This will extract all the driver files into a directory on your hard drive. The directory these files are extracted to will have a similar name to the file that was downloaded (i.e., c:lj4100pcl5ewin2kxp). However, you can change the path and directory name at the time of extracting the file.
    * Open the Printers Window (Click Start-Settings-Printers).
    * Update the printer if it was previously installed
    o Right click on the printer and select Properties from the pop menu.
    o On the General tab, select New Driver.
    o Click on the Warning Box that pops up.
    o A printer listing box will appear. Select Have Disk.
    o Another box Install from Disk appears.
    o Click the Browse to locate the expanded files directory (i.e., c:lj4100).
    o Click on the file ending with .inf .
    o Click Open and then Okay and let files install.
    * Add the printer if it hasn't been installed yet.
    o Click Add New Printer
    o Follow the instructions of the Add Printer Wizard.
    Regards
    Here another step by step wizard on how to cnfigure postscript printer.
    http://www.sketchpad.net/config-ps-print....
    I hope this helps you *** well.
  • Benjamin Jr Singson Apr 01, 2011
    Hi try this configuration.
    Avoiding Font Substitution - Configuring Windows® XP PostScript® Printer
    Buy Graphics & DTP Software!
    Books on Graphics & DTP
    Graphics & DTP Training CDs
    Configuring a PostScript Printer to Avoid Font Substitution - Windows XP
    1. Start by opening your printers folder:
    2. Right-click the printer you want to configure and choose "Properties" from the context menu.
    3. From the "General" tab, click the "Printing Preferences" button.
    4. A Layout Options dialog will open. Click the "Advanced" button.
    5. In the "Graphic" section of the Advanced Options dialog there is a "TrueType Font" setting. The default setting is "Substitute with Device Font". This is the setting we want to change so the printer will use the installed TrueType fonts instead of the printer's built-in device fonts. Click the "Substitute with Device Font" hyperlinked text.
    6. Clicking the "Substitute with Device Font" hyperlinked text in the Graphic section of the Advanced Options dialog will display a drop-down menu.
    7. Choose "Download as Softfont" from this drop-down menu.
    8. Choosing the "Download as Softfont" option will ensure that trueType fonts are sent to the printer. That's it. You're done. The printer is now configured to send TrueType fonts to the printer and bypass the printer's font substitution table.
    Note: The following steps are to demonstrate how to edit the printer's font substitution table. These steps are not necessary if you have done steps 1 - 8 above, but they are shown here for instructional purposes only.
    9. Click the "Device Settings" tab. Here is where you can edit the printer's font substitution table. Click the plus sign to the left of the "Font Substitution Table" section to expand it.
    10. Scroll down to where you see a font that is being substituted for one of the printer's built-in device fonts. In the screen shot below, Arial is substituted with Helvetica. Click the "Helvetica" hyperlinked text to change it.
    11. Clicking the "Helvetica" hyperlinked text will display a drop-down menu.
    12. Choose "Don't Substitute" from the drop-down menu.
    13. Setting each substituted font to "Don't Substitute" will force the printer to use the actual TrueType font instead of one of the printer's built-in device fonts. Editing the printer's font substitution table is one way to accomplish this.
    I hope it helps you.
How do I fix a 49.FF04 Service Error on an HP Laserjet 4100n
This could be several things. But most are firmware related
Unplug it from the network and power it off, then on. Does it come to ready? If it does there's a bad print job on someone's computer. Or less likely the network port is bad. Clear out all print jobs on the network then submit a new print job. If it prints, great, if it codes again, clear it and try from a different computer.
if you're printing from a Mac can probably get away with updating firmware or changing the PPD for the printer.
if its windows printing I would replace the formatter board. If you have one lying around you could try plugging in a jet direct card and seeing what it does, but I wouldn't order a jetdirect card, I'd replace the formatter.
Aug 11, 2014 | HP LaserJet 4100n Printer
The logic card of my TallyGenicom 6312L line printer has been repaired. it is not working on Unix OS but working in Windows envirinment. what is the solution?
The solution depends very much on the cause of the problem. I note that you can print from Windows, this indicates the intrface you are using is functioning correctly and it should therefor be possible to print from Unix to the same interface if it is connected to the Unix system. If the printer is connected via a network interface, check the IP address on the printer to ensure it matches the IP address set up for the Unix print queue. Try pinging the printer from Unix. Ensure the EMULATION setting on the printer matches the Device Type selected on Unix. You may need to identify if any data is being sent for Unix perhaps try sending a test text file to the printer. A common cause for printers not printing from Unix is no Carriage Returns or Line Feed commands in the data. Try setting Auto CR to ON in the printer, of this does not work try setting Auto LF to on. If there is still a problem please post the connection method and also any errors or symptoms seen when printing from Unix
Sep 27, 2011 | TallyGenicom 6312 Matrix Printer
The printer (hp laserjet p2015) appears offline
Press and hol the green 'go' button until the lights flash, (about 4-5 seconds) and release the button,
Wait for the config pages to print out, and then check your network configuration, i.p address, Subnet mask and gateway.
If no network page prints out, you might have a dead Network Interface in the printer.
May 10, 2010 | HP LaserJet P2015dn Printer
I want to print from my HP Laserjet 4100N tray 2 instead of tray 1. How can I do that?
Do a Configuration Page print out from the printers 'Information Menu'
Perform a paper path test from tray 2;
<Information Menu> , <Item> , <paper path test> , <Select> , use <Value> to select <Input Tray =2> , <Select> x 3 times.
Is the print out correct?
Check the paper size setting for Tray 2 matches the size you are trying to print onto.
Check / Adjust setting in the 'Paper Handling' menu.
Make sure Tray 1 has no paper in it when you send the print Job.
Check your Driver settings in Windows
Dec 22, 2009 | HP LaserJet 4100n Printer
My printer canon ir2022n network printer does not print from my new vista business OS computer
Windows sharing based printers are dependent on the computer where the printer is attached. This means that if the computer is turned off, or is in the sleep/hibernate mode, then all the computers that can print through that server will not be able to print. To solve this issue you can use external print servers to share printers in the home/office. External print servers are connected to the router which allows it to be available on the network without being dependent on any other computer system. External print servers are available in both wireless and wired versions, and the choice between those options is based on the needs of the home or office.get more information and help for Network Printer Configuration .Hope this helps you.
Oct 13, 2009 | Office Equipment & Supplies
Trying to reinstall 3 computers to a laserjet 2840 network printe
pls spooler service strating contorl panel - administrator tools - service -spool service start ok
Feb 21, 2009 | HP LaserJet 2840 All-In-One Printer
Plz help me am in trouble
Network Configuration page
NOTE The Network Configuration page is only available on the HP LaserJet p2015n,
HP LaserJet p215tn, and HP LaserJet p215nw printers.
A Network Configuration page prints whenever a printer configuration page is printed. You
can also print a Network Configuration page by pressing the network Reset button at the
back of the printer
The Network Configuration page provides information about the network configuration,
including the IP address, firmware revision, network statistics, protocol information, and so
on. The Network Configuration page automatically prints when you print a configuration
page from the control panel.
ENWW Printer information pages 37
Using the HP Toolbox
The HP Toolbox is a Web-based program that you can use for the following tasks:
● Check the printer status.
● Configure the printer settings.
● View troubleshooting information.
● View online documentation.
You can view the HP Toolbox when the printer is directly connected to your computer or
when you are using a supported network connection. You must have performed a complete
software installation to use the HP Toolbox.
NOTE You do not have to have Internet access to open and use the HP Toolbox. However, if you
click a link in the Other Links area, you must have Internet access in order to go to the site
associated with the link. See Other links for more information.
To install the HP Toolbox, you must install the TCP/IP protocol and the most recent version
of the Java™ Virtual Machine on the computer. You must also install the DOT4 protocol for
all USB connections, LPT connections for Windows 2000 and Windows XP, and LPT1
connections for Windows 98 S.E., Windows Me, and Windows NT 4.0. See the system
administrator or computer manufacturer's documentation for more information about
installing the TCP/IP protocol and the DOT4 protocol.
Jan 22, 2008 | HP LaserJet P2015dn Printer
Printer Pauses every few pages, seems to print slower than it shouls
More likely to be Network print spooler issue, check settings on driver.
Nov 09, 2007 | HP LaserJet 4100n Printer
H.P laserjet 4100 series.
Printout a copy of your printer configuration. Press the right-side of the MENU button once, then the right-side of the ITEM button twice, and press the SELECT button once. This will print out a configuration page. In the lower right part of the information on this page, it will give you stats on the Paper Trays and Options. Standard settings on these should be "Default Paper Size: LETTER, Tray 2 (LETTER). If either of these says anything different, I would do a cold-reset on the printer to reset it to factory defaults. If you have a network card installed, you need to pull it out before doing this. To do a cold reset, turn the printer off, then hold down the GO button and turn the printer on. Wait about 5 seconds, then release the GO button. Also, you need to check your print setup on your PC. I am assuming you have a WindowsXP machine. Click START, SETTINGS, PRINTERS&FAXES. Right-click your printer icon and select PROPERTIES. Click the PRINTING PREFERENCES button at the bottom. Click the PAPER tab. Check the boxes at lower left. "Size is should be Letter", "Source is & Type is should both be Auto Select". Click OK, click OK, and exit the Printers Window. Lastly, I would make sure that you have Letter size selected from the application you are trying to print from. Hope this helps.
Feb 26, 2007 | HP LaserJet 4100n Printer
HP LaserJet 4100n Printer Logo
Seeker5211
Seeker5211
