Question about Kitchen Ranges
I have an A7 Code showing on my GWH 635ES tankless water heater. What do I need to do? My location is near Stockton, CA.
  • rrostomily75 Mar 31, 2011
    Turned the power off for 30 mins then turned it back on and the error code went away. Thanks for your help anyway.
    Rich
  • 4,323 Answers
Hi
A7 error is a Hot water temperature sensor/receiver defect (from control unit). To solve this issue you will have to check the water temp. sensor and its connections. Before checking that you can also check the room area temperature as it must be above 36 degree Fahrenheit (2 degree Celsius). Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 31, 2011
How do i gas heater gwh 2400 ctd efs Lp
Stupid me but could you be a little bit literate in asking a question.
My dog write better questions that I can understand than this scribbling.
A GWH 2400 is the little brother of the GWH 2700 much like the 635ES. If you have an LP model be sure to use the overpressure protection valve supplied by Bosch as overpressure in LP (above 10-14" WC) can completely destroy this unit.
And you can use a TPR or PRV for 170,000+BTU being sure you get a House Pressure valve of 60-80-100 PSI+ and not the boiler PRV for 30 PSI
Beyond that your questions above states nothing recognizable as a technical question
Oct 19, 2014 | Bosch & Tankless LP Hot Water Heater
My GWH 715 ES cannot restart after hot into cold water crossover
Check for obstruction in your watervalve. It has a flow meter, that needs to spin freely. Remove the watervalve and blow through it, you should hear it spin.
Also make sure you dont have an error code showing. Hold down your reset button for 5 seconds to reset an error code and get back to your set temp.
Jan 02, 2014 | Bosch ProTankless GWH 715 ES LP Tankless...
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
Aug 14, 2012 | Bosch & Tankless LP Hot Water Heater
Where can i download a GWH 715 ES manual?
Are you looking for sell sheet pdf, or install-care manual, or service manual.
Search: GWH 715 ES manual .pdf
Adding .pdf to search parameter helps locate manuals.
Sell sheet with venting overview, technical and product specs:
http://www.globaltowne.com/manuals/sell_sheets/715-800SellSheetFINAL.pdf
Manual for ES high altitude, with installation, error codes and troubleshoot:
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
I cannot find a service manual, or service bulletins:
http://www.bosch-climate.us/support-center/downloads/bosch-manuals/earlier-models.html
Aug 11, 2011 | Bosch ProTankless GWH 715 ES LP Tankless...
What is an A7 code? Gas hot water heater
Before calling service technician, open following links for Bosch troubleshoot resources:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Error codes are start-point for troubleshoot.
A7 is temperature sensor fault.
This can be bad wiring, corroded wiring, failed sensor, very high temperatures due to other part failure.
Other cause can be water filter clogged, lime and scale inside heat exchanger, faucet aerators clogged, or combination of problems listed.
Each tankless manual across all manufacturers suggest maintenance schedule: clean water filter monthly, delime heat exchanger yearly, and yearly service of burner and other parts by trained service technician which can address cause of most error codes, and might solve some problems before they happen.
If tankless becomes chronic issue, solve problem yourself, same day, for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Jul 31, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch on demand tankless water heater gwh 2400 E LP error code "
BOSH AQ 250 On demand propane water heater ran out of propane, got gas now, but get EC flashing on the display and the unit won't fire? Lost manual, any suggestions. Thanks, Jim
Jan 06, 2010 | Bosch AquaStar 2400ES-NG
Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
Bosch Pro tankless water heater overheating
The vent pipe you use is the correct size for the heater.Longer runs require bigger pipe.I also would check to see if the water is getting to hot.
Mar 16, 2009 | Bosch ProTankless GWH 715 ES LP Tankless...
Burner will not light
Try this web site!
http://www.protankless.com/BoschProHome/GasProducts/BoschGWH425HN/tabid/506/Default.aspx
Copy & Paste to Google search engine.
Jan 27, 2009 | Bosch ProTankless GWH 715 ES LP Tankless...
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
