Question about Hot Wheels Kmart 12" Boys Bike
Missing chain guard - Hot Wheels Kmart 12" Boys Bike
  • 58 Answers
If it's new and should have the guard then go and change it,if not from a bike shop buy one.
Posted on Mar 31, 2011
  • AVRELIANVS Mar 31, 2011
    You can also try making one from a piece of plastic or tin
Two banging sounds with each rotation
Most beach cruisers have a chain guard. There is always a slight "wobble" of the front chain ring, check to make sure the chain isn't slapping the chain guard. The chain guard can be adjusted. The chain also might have loose tension causing it to bounce around just enough to hit the chain guard. The opposite may be true, if the chain is too tight, you could be getting a popping sound at certain points on the chain as it messes with the gear teeth, in this case loosen the chain slightly to put a little slack in it.
Jan 14, 2014 | Huffy 26 in. Cranbrook Cruiser Bike
Chain came off
Take off your chain guard, should be 2 bolts holding the chain bar in place. Then make sure there isnt another bolt or screw you missed, pop off cover put chain on, replace chain guard and tighten chain. It should be that simple
Jul 22, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I have a Jonsered 20"chainsaw.CS2165
The hand guard is secured on the left side with the top l/h starter cover screw part no. 503203419, the right side is held to the brake actuating arm with a 4mm screw part no. 503202512.
Let me know if you need other parts.
Jun 05, 2011 | Garden
I recently purchased a 20"
The chain guard is usually fastened to the seat tube of the bike (the frame tube coming up from the pedal area to the seat) with a plastic band. If this band is broken or missing, and there is excessive play in the chain guard, I suggest removing it entirely or returning the bike as it may be a hazard.
Mar 15, 2011 | Mongoose Cycling
Excessive oil from the chain oiler. oil resevoir is empty and fuel is still 3/4 full. Saw is two weeks old. Oil sprays off the bar.
What kind of oil did you put in there?? The bar and chain oil is so thick, i can't see it slinging anywhere, you must have used 2 stroke in there. It's OK, That is all I use in my Husky, but it doesn't sling off. I don't know if you have a part missing or what, but there is a little damper right under the chain guard. Check it out, hope this helps.
Oct 19, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I just bought a La Jolla 26' men's bike and the pedal stem is scraping on the chain guard. How and where do I make adjustments?
Examine the top of the chain guard where it mounts to the bicycle. Loosen the fasteners enough to slide the chain guard in and out. Adjust it so it doesn't hit the crank or rub on the chain and tighten the fasteners back down.
Jan 19, 2010 | Cycling
I am trying to replace the chain on a swinn pixie bike--but thereis a chain guard that is giving me troubles--I need to know how to assemble the chain with the guard
see if theres a master link on the chain and take off from that way you dont have to take off the guard. the master link will look diffrent from all the other links and can normally be removed with a screwdriver
Jul 02, 2009 | Cycling
Hot Wheels Kmart 12" Boys  Bike Logo
178 people viewed this question
Top Hot Wheels Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Hot Wheels Cycling Expert? Answer questions, earn points and help others
