Question about Sony Cyber-shot DSC-W70 Digital Camera
Can't get snap Shots and flasher not flash - Sony Cyber-shot DSC-W70 Digital Camera
  • 58 Answers
Does the camera power on? if just turns on and nothing can be done than try to replace the battery or charge it and see if same.Check for the zoom not to be maximum.
Posted on Mar 31, 2011
Emergency flashers and turn signals stopped working in my 2000 Montero Sport
The most likely cause of the problem is the flasher unit. It's usually in a small metal can or plastic box that plugs into a socket somewhere in the car (usually under the dashboard, but sometimes in a fusebox in the glove compartment, or less commonly, under the hood). Go to any general car parts store and ask for the turn signal flasher for your model. When you have the replacement in hand, you'll know what you are looking for, and the installation instructions may even tell you exactly where to search for it. The part costs about $3 - $7.
If you're wondering how it works, flashers are usually thermostat-type switches with a built-in heater - when it's in one position, the heater warms it up so it snaps to the other position. When it cools, it snaps back. The current for the heater goes through the turn signals lamps, which explains why it flashes more rapidly or not at all if you have burned-out lamps. Failure modes include fatigue cracking in the bi-metal switch element and burned-out contacts.
If the flasher doesn't fix it, you may have a break in the power wire going to the turn signal lever or a short-circuit (blown fuse) due to damaged insulation somewhere in the turn signal light wiring.
Sep 09, 2011 | 2000 Mitsubishi Montero Sport
I have HP designjet t 1200 series printer ..Today while feeding the paper inthe roller it says remove the roller and feed the paper inthe roller 1 .what is the problem????/
For Tech Gus only:Error message: Remove paper from sheet path:
Resong: Dut dust formed on paper sensing IR sensor.. Remidy.. check the snap shots to clean paper sensor, contains how to remove, clean.. Remove right door then start follow the snap shots...11_19_2011_12_44_55_pm.jpg11_19_2011_12_45_17_pm.jpg11_19_2011_12_45_56_pm.jpg11_19_2011_12_46_48_pm.jpg11_19_2011_12_47_35_pm.jpg
Fix all carefully.. Best of luck..
Jul 12, 2011 | HP Designjet T1100ps Printer
I want to click pics at night but even with its flash on .... pic quality is nt so good ................ is there any night mode function on Canon PowerShot SX130 IS camera ......if yes please tell me...
you have a dial on top of your camera. where you can find 2 types of shots. one is Night scene. and other is Night snap shot. Second one is better.
Note that even a small hand shake will spoil the subject. Use a tripod for night shotting with flash
Jan 01, 2011 | Canon PowerShot SX130 IS Digital Camera
Replace turn signal flasher
The flasher unit is located on the RH steering column opening reinforcement, and is attached by a bracket.
The combination turn signal and hazard flasher can be removed by pressing the plastic retaining clip (attached to the flasher housing) and pulling straight rearward. To install a new flasher, align the bracket with the track on the flasher housing. Then push the flasher forward until it snaps into the bracket.
Jun 03, 2010 | 1991 Ford Thunderbird
Turn signal switch replacement on 93 buick park avenue
The steering wheel does have to come off.
Below is the process for replacing your turnsignal switch and the special tools needed.
Many vehicles use a turn signal switch that is separate from the multifunction switch. The steering wheel will have to be removed to gain access to the turn signal switch on these vehicles. The following procedure is a common method of turn signal switch replacement:
  • Place the fender covers on the fenders.
  • Disconnect the negative battery cable.
  • Remove the steering column trim.
  • Remove the horn pad from the steering wheel.
f_aee_cc14.28.jpg Steering wheel attachment. Courtesy of General Motors Corporation, Service Technology Group.
  • Remove the steering wheel and horn collar.
  • Use a suitable puller to remove the steering wheel.
  • With a suitable compressor, compress the preload spring to the lock plate. Compress the spring only enough to remove the snap ring.
f_aee_cc14.29.jpg To remove the snap ring, use the compressing tool to relieve the pressure against the snap ring. Courtesy of General Motors Corporation, Service Technology Group.
  • Use a pick and a small flat blade screwdriver to remove the snap ring.
  • Remove the lock plate, horn contact carrier, and spring.
  • Remove the bolts at the upper steering column support and the upper mounting bracket from the column.
  • Disconnect the turn signal wiring connector.
  • Wrap tape around the wire and connector.
  • Remove the hazard warning knob from the column.
  • Remove the switch retaining screws and remove the switch.
f_aee_cc14.30.jpg Remove the turn signal switch from the column. Courtesy of Chrysler Corporation.
  • Replace the switch and reverse these procedures for reinstallation.
On vehicles equipped with cornering lights, the turn signal switch has an additional set of contacts that operate the cornering light circuit only. The contacts can receive voltage from either the ignition switch or the headlight switch. If the ignition switch provides the power, the cornering lights will be activated any time the turn signals are used. If the contacts receive the voltage from the headlight switch, the cornering lights do not operate unless the headlight switch is in the PARK or HEADLIGHT position.
The most common complaints attributable to the flasher are too fast or too slow of a flashing rate. If the flasher is of the wrong type and rating, the amount of time required to heat the coil will differ from what the manufacturer designed into the circuit. Also, newer flashers that use electronic circuits will flash at an increased speed if one of the turn signal bulbs is burned out or the circuit is defective. If the flasher is rated higher than required, the flashing rate is reduced because it takes longer for the current to heat the coil.
Check the size and type of light bulbs in the circuit. Use only the lamp size recommended by the manufacturer. If these checks do not correct the problem, test the generator output. Higher or lower voltage output than specified may cause the flasher rate to be incorrect. If the charging system output is within specifications, check for excessive resistance in the turn signal circuit. Check both sides of the circuit.
If none of the turn signals operate, check the fuse. Next, check the flasher. Remove the flasher from the fuse box. Connect a jumper wire across the fuse box terminals. If the turn signal lamp operates with the lever in either indicator position, the flasher is faulty. If the lights still do not illuminate, test the turn signal switch.
Aug 25, 2009 | 1993 Buick LeSabre
D80 won't take pictures sometimes unless I turn it off and on
It may be that you are shooting in a light level that is too low (indicator light) try upping the ISO and are you using the built-in flash or a separate flash?
Nov 25, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nexxtech webcam continually snapping shots and won't stop ???
Try pressing it again as it sounds like it is switched on. Worth a try.
Hope this helps. Bud
Nov 13, 2008 | Computers & Internet
Indoor Shots
try to adjust the mode in which you are taking the snaps....like NORMAL,DYNAMIC,USER,ETC
thanks
Feb 12, 2008 | Premier Electronics DC4311 Digital Camera
Flash rebound
A camera flash against a glass, or any reflective surface, will bounce the flash light right back at you. Turn off flash when shooting through glass. Note flash is only for shots less than 12 ft distance. It take it you are shooting scenery shots through vechicles or buildings, ie, long scenery shots anyway, so flash does nothing but bad things.
Nov 01, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
80000 snaps
I would think it implies the camera / flash / whatever is still functioning after that many operations (pictures)... of course everything wears out eventually, film, digital cameras and flash too. In this year I may hit 15,000 pictures with my FZ10... I expect the mechanical (zoom, doors, buttons & switches) will last several years. My vivitar 283 flash units may hit 2,000 flashes this year.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
19 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
