Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
In dorr panel freezer not cold enough
The lights in the inside panel keep going out. We unplugged and they came back on......but went off again. One more time but still went off again. The freezer said it was at 16 degrees. Some of the food is frozen some not. Any suggestions?
  • 639 Answers
Dear FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
DO NOT COVER THE AIR VENTS IN THE BACK OF THE FREEZER. THE FREEZER AND FRIDGE SHARE THE AIR!
OTHERWISE
SOUNDS LIKE A ELECTRONIC OR CIRCUITRY PROBLEM . CALL SERVICE . SORRY!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS.PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OUT!
Posted on Aug 26, 2008
Why did the control panel go dark on my Maytag side by side refrigerator for a couple of hours?
Ron,
You're right to be concerned but I'd just keep an eye on it for the time being - if it ain't broke, don't fix it!! It's entirely possible that it's throwing a hissy fit after the power outages and it just needs peace and quiet so it can settle down!
Sep 22, 2015 | Maytag Refrigerators
I have a Britannia nabraska side by side fridge freezer. All of a sudden the freezer compartment is not cold enough as though the door had been left open - but 24 hours later has not got colder
You may have a bad thermostat or you could just be frosted over inside. You'll need to look behind the back panel in the freezer for syntoms if unplugging to defrost doesn't work.
Mar 23, 2015 | Refrigerators
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
The control panel went out the oven fan still blows but the oven does not heat up nor do the panel light up
if this is a new oven/stove its possible there is a fuse that has went out. pull away from wall (unplug) start looking everywhere you can for a fuse, keep a magnet handy to keep your screws together, or just place in a bowl. also a flashlight is handy. try to hunt down the issue yourself if you cant afford to have it serviced. I had my refrigerator stop cooling , fan was blowing just no cold air, I pulled it out and looked inside the motor area and noticed a wire had been chewed in half by a mouse, unplugged it ,spliced the wires back together, black tape, plugged back in and shazam ! fixed..then the mouse hunt began!! good luck
Sep 27, 2013 | Kenmore 42161 / 42169 Electric Single Oven
MY REFRIGERATOR CONSTANTLY RUNS BUT FREEZER DOES NOT FREEZE AND FRIDGE DOES NOT GET COLD. ONLY A LITTLE COLD AIR BLOWS FROM INSIDE OF FREEZER BUT NOT COLD ENOUGH. FRIDGE MOTOR JUST KEEPS RUNNING AND
Can you tell me if there is a layer of frost covering the back panel inside the back of the freezer? Here is a photo of a panel that has frost building because of a defrost problem HERE
Here is a GD5NHAXMB00Parts Manual go to page 16 and item number 6 is the 2303804 User Control and Display Board
The board could be the problem causing defrost failure or the W10135091 Electronic Control Board
Sometimes these boards will have burn marks or signs of heat damage but not always. Can you unplug the refrigerator and examine the above board first? It can be found on page 17 and item number 18 Once you have done this and see no problems we will examine the defrost heater 2323198 Defrost Heater
I am here to help you resolve this problem so please respond Thanks Sea Breeze
Mar 29, 2013 | Whirlpool GD5SHAX Side by Side...
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
My Maytag refrigerator is not getting cold enough. The bottom (freezer) section is working great, but the top (refrigerator) section is fairly warm....still cool but not cold. It was noticeably colder a...
I had the same problem and had to change the control board, the technician showed me how to defrost manually to keep the fridge cold until he could get the new control board and change it.
Open the refrigerator door push in the light button to turn off the light inside the fridge at the top (keep it pushed in) then push the left button of the refrigerator temperature setting 3 times and let go of the light button the letter "d" will be displayed. Push the left button one more time number "5" will be displayed, push the left button a third time and you will hear noises this should start the defrost process. Wait a while then open the freezer and check the coils on the back wall of the freezer, the ice should have melted. Wait a couple of hours and your fridge should start getting cold again.
Aug 10, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Freezer side keeps running, other side not cold enough
Sounds like Defrost timer or circuit is not working. Look for ice build up at the back of freezer. Unplug and remove rear panel inside freezer. Are the coils covered in ice? If Yes allow it to defrost then check defrost heater, limit thermostat and defrost timer. Chances are one of these is bad. Also Check the circulating fan for correct operation.
Mar 29, 2010 | Jenn-Air Refrigerators
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
57 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
