Question about Canon FAXPHONE L80 Laser
My Canon L80 is displaying the message "CLEAR PAPER JAM". I have made sure there is no paper jam but the message continues to show, thus making the machine inoperable. Can you give me any suggestions?
  • Canon Master
  • 17,970 Answers
I assuming that actually dont had a paper jam prior to this message and dont have any paper disappear inside the Fax, then I could suspect the paper mis fed from the tray at the rear. That model can sometimes feed several sheets together or twist the paper as it is pulled into the printer.
Just below the sheet feeder is a jam sensor that is basically a plastic flag that when pushed by the paper breaks a light beam to indicate the paper is passing. If you get a paper jam in a printer it is important that the paper is removed in the direction it would normally feed through the printer.
If it is pulled against the normal flow of the paper then that plastic flag can break or be pulled off of it's hinges and cause a constant jam error. Either there is something still in the printer holding the jam sensor down or this has happened in your case.
There are 3 jam sensors across the path of the paper and 2 of which can suffer this problem. The one I mention and 1 in the fuser at the front. You would use a flashlight and make double sure that there are not obstructions that you can see either at the rear tray or the fuser.
If you can't find anything then the jam sensor are going to need to be checked but the rear jam sensor in particular is hidden beyond easy reach and involves quite a strip down to access so you may want to consider letting a technician do that for you.
If it had fed multiple pages in at once i would consider a new paper separation kit as they are easily fitted when the jam sensor is checked as they occupy the same area. Once multi feeding has started it often becomes frequent.
Hope helps.
Posted on Mar 31, 2011
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
My printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
My fax machine is displaying "Clear Paper Jam" I have looked every where and can't see a piece of paper stuck in it. This is making me unable to recieve faxes but allows me to send them....
it is the paper jam sensor thats giving a false reading. It can b a very small piece of paper that u can easily remove with ur hand or by blowing. Open it, remove ink catridges, blow it thoroughly n make sure all sensors are clean of dirt. Also mke sure tht the paper u use is preheat to avoid these paper jams. Hpe it helps, pliz vote. Good luck.
Jun 08, 2011 | Canon FAXPHONE L80 Laser
DISPLAY SHOWS "PAPER JAMMED "READING
I think it still have maybe a very small paper jammed.
Tries dismount the more you can from printer, since I'm almost sure it stills remains maybe a very small paper...
Apr 14, 2011 | Canon PIXMA MX300 All-in-One Printer
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Paper jam
When this happens it is because the pick up tire has either worn out or has alot of paper lint on it. Remove the toner and I think on this one you can see a rubber wheel in the back middle. You can clean this with a little windex or all purpose cleaner. If it will not pick up the paper after that the tire needs replaced.
Oct 13, 2008 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 Laser Logo
46 people viewed this question
old marine
old marine
