Question about Texas Instruments Office Equipment & Supplies
Omni 800 model 885. This machine is printing clearly but it prints a page normal and as the print goes from page to page the darkness of the print fluctuates from dark to light. Since this is a continuious feed printer it goes from good dark invoices to very light print then back to dark. Ribbons are not lasting more than a week because when the print head backs off the invoices are too light. Any help would be appreciated. Melba
SOURCE: R1800 printer problem
I fixed the problem, the PW and Ink Mark sensors needed cleaning. I was able to access and remove both sensors after removing the printer housing, and moving the print head to the far left. There's enough space to unscrew the cover for the sensors, and unplug them with needle nose pliers and a couple fingers, clean them both, dry them, re-install, etc.. all is well now after some re-alignment procedures with the epson factory service program.
Posted on Feb 15, 2008
micromaster
  • 3614 Answers
SOURCE: HP Laserjet 6L Dark Printing
Check your Toner, and also the thermal roller of the printer..
Thank you
Posted on May 29, 2008
checkitright
  • 1362 Answers
SOURCE: Jet ink on printed invoices
Clean inside for toner spills
check fuser may be worn
check drum ( green Cylinder of toner cartridge) --Rotate--
Posted on Jul 15, 2008
  • 4090 Answers
SOURCE: HOW DO I FIX A BLACK LINE ON BACK OF PAPER WHEN PRINTING
ink on one of the guide rollers will cause this
Posted on Sep 14, 2009
JackHeath
  • 1049 Answers
SOURCE: Printer leaves a grey haze on the page.
If your fuser is not failing then someone probably didn't install the toner properly. Regardless, it is incredibly hard to clean toner out from all the guts and the gray won't go away as long as it is there. I would take it outside, wear a smock, and blow it out with an air compressor or half a dozen cans of compressed air. Wipe down and clean every part you can.
Replace the toner cartridge. Then run a couple dozen copies of something to pick up the remaining toner from the internal mechanisms. See if their is any more toner. If there isn't...then somebody messed up and you just need to work the last of the toner out of the innards.If there is more toner after you clean it out and replace the toner cartridge, start thinking about replacing the fuser.
Posted on Oct 02, 2009
Testimonial: "Thanks so much! That was fast and helpful. "
How do i retreive and receive faxes? My machine has recieved material in memory, yet when i try to print them, the alarm rings after first page and display reads "CHECK PAGE SIZE, press OK" It will re
If you are able to print normally from this model, despite the 'stuck' faxes, then it could be that you have been sent a document that is not the same size as that in your tray. Try cutting A4, if that is what you have, down to 'legal' and see if will move on to next page. If this works, cut some more and print job till finished.
If the above makes no difference, you may have to do a memory reset to clear a corrupt fax record. Caution! this would clear all faxes queued in your machine.
Dec 16, 2014 | Canon PIXMA MX340 Inkjet Multifunction...
Why do I get bleed through of print on pages I print out at bottom of page or shadow print on some?
Paper is too thin (use higher "pound" paper).
-or-
Toner is not of good quality (use HP Brand if possible)
-or-
Printer is set to dark or heavy in your page setup (change to normal or even light)
You can also make sure you are using an HP print driver instead of a generic print driver. Go to HP.com and search print driver for you model, download and install (if you don't already have an HP printer driver loaded on your PC).
Jul 29, 2014 | HP LaserJet 3050 All-In-One Printer
Xerox 8500 phaser prints brown tint
Most likely the cyan ink is burnt. If the ink sticks are left unused (printing more black than color, this will happen.
Print the test pages for PQ troubleshooting from the control panel and examine each print. Cyan will probably have very dark streaks down the page, magenta should look normal, and yellow also will have dark stripes. You need to replace this burnt ink, and the only way is to print. From within paint (or similar accessory in other OS) Create a full page of cyan, and print about 100 - 200 pages, or until the cyan starts to clear up. Yes it is a waste, but much cheaper than a print head, Do this for yellow as well.
Apr 15, 2014 | Xerox Phaser 8560DN Laser Printer
Hi my omni 3200 printer is not printing. The page
You either have the wrong paper in the machine or it is in backwards. It takes thermal paper. Run your fingernail across the paper and if it makes a mark, that is the side which must be facing up when it goes trough the printer.
Jun 19, 2010 | VeriFone OMNI 3200 (P092-101-10) Printer
Omni 3740 not printing dark enough
The print on our Omni 3740 is not working. We have to push the cover down hard to make it print. I think the roller is not pushing hard enough or the clamp to hold the cover is out of alighnment. Need help.
May 26, 2010 | Office Equipment & Supplies
Printer will print test page but nothing else
there is a communication failure between the printer and the computer. uninstall and reinstall the printer driver. your problem will be resolved.
Aug 04, 2009 | HP PSC 1410 All-In-One InkJet Printer
Copy Quality
open lid press copy is scanner bulb bright white if not bulb is burning out or has burnt out
Sep 08, 2008 | Lexmark X7170 All-In-One InkJet Printer
Panfax uf 885
If it happens on all printouts, and not just from one sender, then replace the toner cartridge. That will clear up most image related issues.
Jan 18, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
146 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
