Question about Frigidaire PLHS67EGSB Stainless Steel Side by Side Refrigerator
My FRIGIDAIRE PLHS67EGS, was leaking water from the filter inside, every time i get water or the ice maker take water. I take out the filter and stop using the water system, but at the same time when the Ref. get the defroster cycle, the compressor do not start again, then i unplug the electricity, wait a few minutes and plug again, then the system work well for aprox. 12 hours. All time the electronic display show # 4 intermitent, at the right side (Ref side). Can you help me with this problem??? My name is Anibal Navas P., and my e-mail is: anavasp@bellsouth.net Thanks for help.
3 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Ice maker leaks.
You have a bad switch in the ice maker need to replace whole ice maker or the switch
Posted on Aug 25, 2008
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
My Frigidaire model FRS24ZGE leaks water from the bottom of the freezer door after using the water/ice dispenser. Any ideas on a fix?
Posted on Jul 18, 2009
Ice maker quit making ice how to find problem
Good Morning Friend,
I understand that your Frigidaire refrigerator, model# FRS26R4A, stopped making ice. Here are a couple of suggestions you may try, to get your ice maker to produce ice.
    1)Make sure that the wire signal arm, inside the bucket area, is in the down or ON position.
    2)Make sure your household water line valve is open and on.
    3)Make sure your freezer is cold enough.
    4)Make sure the water dispenser is dispensing water. If not, the ice & water filter cartridge is clogged or restricted by foreign material, and must be replaced.
    I hope this is helpful.
    -Best Regards-
    WP
May 22, 2014 | Frigidaire FRS26R4A Side by Side...
Leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Jul 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire PLHS67EESB0 ice maker stopped not making ice and the ice ejector keeps turning and the machine keeps filing with water and overflows
If the ice ejector turns constantly, and water flows with each turn, you have a bad limit switch inside ice maker. This switch stops the motor inside, and thus the ejector, and allows for a freeze cycle. There are other possible problems but i suggest just getting a new ice maker. Not that hard to change out if you have any mechanical skills.
Oct 12, 2013 | Frigidaire Refrigerators
Frigidaire Gallery French Door Refrigerator ice maker not making ice
You can search with your model number to see if a filter is available or not. Secondly unless the ice maker was damaged for sure it's likely that the fan is not running in that compartment or air is leaking into the refrigerator and making the ice maker think its not cold enough to make ice.
Apr 13, 2013 | Frigidaire Gallery 25.8 Cu. Ft. French...
Frigidaire water stopped working...ice maker.dispenser fine
You probably have an obstruction in filter compartment. you should remove filter and inspect o rings etc. or anything that could have clogged it up. The only other thing that could be the cause is a bad water valve. Side by sides have a double water valve. one for water ,one for ice maker. You can check this by having someone flip ice maker arm down so it calls for water and feel water valve as it runs and possibly hear it too. Hope this helps.
Jul 24, 2009 | Frigidaire FRS23KF7AB Side by Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water to ice maker isn't filling tray.
what is the inside temperature in the freezer? it has to be below 17 degrees before the ice maker even try's to work
Dec 11, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker leaks.
Jul 25, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire SBS
reach into the ice maker hook the ejector blades with a finger and pull them up a little you will hear a ratchet sound then watch them go around and listen for the fill valve before they stop let me know what happens
Jan 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire PLHS67EGSB Stainless Steel Side by Side Refrigerator Logo
77 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
