Question about Cosco High Back Booster 22-200 /22-207
I took the cover and straps off of the cosco highbakc bc038-PDP and now can't get the car seat back together. How should the straps go?
    Brigadier General:
  • 3,513 Answers
Hi
Place the buckle strap through the slot on the base of the car seat. This will hook into place. Make sure the buckle strap is inserted completely and does not slip out. The buckle's red button needs to be facing out.Replace the pad and cover of the car seat. There will be four elastic bands that will stretch over plastic hooks on the bottom sides and the top sides of the car seat. Before connecting the elastic straps, guide the buckle and side harness straps through the slots on the seat of the car seat padding. The pad and cover of the car seat are needed whether the car seat is used as a booster seat or as a five-point harness car seat.
Clip the top shoulder straps into the buckle. Slide the chest bar onto the shoulder straps.Insert the shoulder straps through the top slots of the car seat. Use the screwdriver to help push the straps through the cover and plastic back slots of the car seat. The shoulder straps must be just above your child's shoulders, not behind the child's shoulders. There are three different shoulder strap slots from which to choose.
Attach the metal clip in the back of the car seat by sliding the shoulder straps over each side of the metal clip.Adjust the tightness of the shoulder straps to fit snug against your child. You do not want the strap to be loose, as this will not restrain the child if an accident does occur.Install the car seat into the car once all the straps and padding have been re-assembled.
Kindly check this link to have more information:-
http://www.ehow.com/way_5505889_cosco-car-seats-strap-instructions.html
Please get back to us if you have further query else please accept the suggestion.
Posted on Mar 31, 2011
I need an owners manaual for a Cosco Car Seat
can you provide a model or maker of that car seat, please?
Feb 19, 2008 | Baby Gear
Looking for instructions for assembling a costco car seats straps
Go to this website and type in your car seat info. If they do not have the manual, I would call the manufaturer's number located on your car seat.
http://www.coscojuvenile.com/Instructions
GOOD LUCK!
PS I just took my car seat apart to wash the cloth material and found the easiest way to reassemble it was to remove the base during install of the straps and then replace the base.
Jul 03, 2010 | Cosco High Back Booster 22-200 /22-207
I HAVE A CAR SEAT THAT I TOOK APART IN ORDER TO WASH THE CUSHIONS BUT NOW I DONT KNOW HOW TO PUT THE STRAPS BACK TOGETHER
There is normally a splitter in the back, a metal piece with two hooks that is attachted to the adjustment strap. the sholder straps latch onto this. You can locate the appropriate manual here: http://www.coscojuvenile.com/usa/eng/Instructions The pages in the back normally discuss reassembly after cleaning.
Mar 19, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
I need instuction on how to reassemble safety straps on cosco car seat. I took apart to wash seat cover and don't remember how to reassemble
Here are the links to download Cosco carseat instructions:
Canada:
http://www.coscojuvenile.com/can/eng/instructions
USA:
Mar 19, 2010 | Cosco Eddie Bauer 22770
Cant put the car seat back together
took the straps off and can't put back together
Apr 02, 2009 | Cosco Alpha Omega 22-180 - with Shield
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
Cosco Car Seat Model Number 22123 Instruction Manual
need instructions ASAP on how to put back together the straps, I took off the cover to wash it. It is NOT EASY to put back.
thanks,
yolanda
Sep 17, 2008 | Baby Gear
I have a 02-442-PRI 11-17-98 Cosco
If you washed the straps, they will need to be replaced. Lock the harness together, to prevent the straps from being twisted. Feed the top part of the harness through the slots that are AT or ABOVE your hangchilds shoulder if the seat is forward facing. IF the seat is for rearfacing, feed the top part of the harness straps through the shoulder slots at or BELOW the child's shoulder. Once each is through, reach down and attach them to the silver plate that hangs from the **** strap adjuster. Once you silde each of the harness straps, then slide the bottom of the through the hole in the cover, then into the base of the seat, folding the top like a triangle makes it easier to get through the tight holes. Repeat on the other side and you are ready to travel! Thanks!
Jun 16, 2008 | Cosco High Back Booster 22-200 /22-207
Cosco Touriva Carseats
I need help putting straps back on car seat
May 15, 2007 | Cosco Touriva 22-100
Cosco High Back Booster 22-200 /22-207 Logo
694 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
