Question about Electrolux Epic 6500 Vacuum
My vacuum shows a full bag after 20 seconds of running. Put a clean bag and the same thing happens.
  • 694 Answers
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Posted on Apr 01, 2011
3 lights show up on the top of my vacuum and the center one I don't know what it stands for. Plus, the vacuum seems to be getting too hot.
The one that looks like a cord plug lights up when the vacuum is plugged in and indicates it's getting power.
The one that looks like a thermometer lights up when the vacuum is overheating, and indicates there's probably a clog in the hose or power nozzle behind the brush.
The next one indicates there is no bag in the vacuum. Machine will not run.
The last one indicates the bag is full and needs to be changed. A full bag or clogged pores will result in overheating, however the vacuum automatically turns off when this happens to protect the motor.
It sounds like you need to replace the bag. If you still have problems, it's probably due to an internal part called a control valve assembly. That is an in shop repair, and the vacuum needs to be taken to an authorized Aerus Electrolux store for service. This is most often due to "made to fit" bags being used instead of "genuine" bags. In this case the motor and interior of the machine need to be cleaned as well. Dirt, even fine dust, in the motor will shorten the life of the motor dramatically.
Dec 02, 2010 | Electrolux Epic 6500 Vacuum
My vacuum stops showing "bag full" even after I
This is most probably due to a worn out or clogged Control Valve Assembly.
Detach the hose and see if it runs. If it does, place hand over hole. If it shuts off, CVA is probably the cause. A clogged CVA is generally due to using generic/made-to-fit bags. Genuine bags have "Home Solutions" printed on them.
You can try turning the dial all the way to the large dot, then try to run the vacuum.
If it is the CVA, you'll need to take it to an authorized Aerus Electrolux store and have their service tech repair or replace the part. I recommend a service and clean of the vacuum at the same time. This will extend the life of the vacuum.
Nov 21, 2010 | Electrolux Epic 6500 Vacuum
The red light on my electrolux vacuum comes on and cuts power.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
Is the style c the right bag. The vacum cleaner only runs about 5 seconds before it says the bag is full.
If you have a 6500, the C bag is the right one. Try turning the dial on top of the vac to the smallest dot and see if the machine will run properly.
If it is still doing the same thing, take it to your Aerus/Electrolux dealer for repair. The control valve assembly (full bag control) needs to be replaced and I don't recomend that you try the repair.
Joe
Nov 01, 2009 | Electrolux Epic 6500 Vacuum
With a new bag -after turning vacuum on, it shuts down
This vac is prone to a control valve failure with the exact symptoms you describe. There is a dial valve on top of the machine designed to regulate how full the bag will get. The valve which sits underneath the dial on the vac likely has a broken plunger and will need to be replaced. Take it to an AERUS Electrolux dealer / shop for an experienced tech to work on.
Sep 13, 2009 | Electrolux Epic 6500 Vacuum
Stopped working, lights work, shows full light when not full.
Remove the bag and put in a fresh bag. Then rotate the dial on top of the vac to the middle position. When cleaning fine dust the vac will shut off before the bag is full as it is sensing a clogged bag and cannot sense proper air flow through the bag. If this persists the sensor under teh top dial may be damaged and need to be replaced
Sep 08, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Aerus Model 152C- vacuum doesn't run
it probably does think you have a full bag.make sure you have it cleaned out and has a bag in there or it might be the sensor for the vacuum and is not working properly. contact your nearest electrolux vac store.or you are not using proper bags.
Jun 28, 2009 | Electrolux Vacuums
Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
Jun 15, 2009 | Electrolux UltraLux 2000 Bagged Canister...
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
89 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
