Question about Honda Garden
How do you adjust a honda lawnmower carburetor: lost of power don't want to go. I took the filter off and it had power i put the filter back on and lost power again
I have a Honda HRR2162TDA lawnmower and I cannot get it running. I have replaced the spark plug, the blade and the air filter and it still will not turn over.
What would be the next solution?
Posted on Apr 20, 2011
    Novelist:
  • 111 Answers
It sounds like your air filter needs to be replaced. I would also check the spark plug to see if there is carbon deposits on it. The socket to remove the spark plug is a 13/16 and it needs to be a deep well socket. This should get the unit back to running condition. The air filter part number is 17211-zl8-023 for a square air filter. If you do not have a square air filter, you will need to take your model number off of the engine (ie Gx160 GJAEA-1111111 and above this is another number like QX2). You can locate the model information by looking at the side of the engine with the dipstick on it. It may be covered with part of the fuel tank/ flywheel housing. It will be stamped into the metal. Any Honda Power Equipment dealer should be able to get the air filter for you. DO NOT use a briggs and stratton air filter. Dirt can leak past the foam seal and can damage your carburetor and could possibly lead to engine failure.
Posted on Apr 01, 2011
I have a toro z150 zero turn lawnmower.. I can put gas in the carb and it will fire but will shut back off as soon as its burnt.. I took a air hose to all of the lines and getting gas past filter.
That is not a simple answer, You would need to continue the cleaning into the carburetor. Make sure your float and needle valve are not stuck. pull the bowl off the carb to see if any gas is in the bowl. if not the chances are that the float is stuck.
May 05, 2016 | Toro Garden
When can you tell when you need a new carb on your lawnmower? .
Hey Julie! It could definitely be something with the fuel float in your carburetor, or as you said, it could be the carburetor in general. You could get a carburetor rebuild kilt and remove the carburetor again, clean it, and rebuild it with new parts, or, you could just go ahead and get a new carburetor, as a dirty or cracked carburetor can also cause a leak of this type. It's really your call on which you want to do! if neither of these fix your problem you may want to take it back to the shop again. Best of luck!
Jul 30, 2015 | Garden
I have a MTD Honda Lawnmower that is having idling trouble. It starts great, but once the chock has disengaged itself the engine surges. If I continue to hold the choke on just a little, it runs just...
Generally this indicates a "lean" condition in the carburetor and there are no adjustments. Depending on your abilities, the best fix is to remove the carburetor and clean all the metering passages/jets. In some cases you are better off just replacing the carburetor. I have seen some Honda carbs. as low as $15-$20. Hope this helps to some degree.
Mar 08, 2011 | Mtd 22" Yard Machine Push Mower
Someone put sugar in my Honda lawnmower's gas tank.
You will need to flush out the carburetor as well. The sugar is clogging up the port that **** gas thru them to the intake.
Dec 18, 2009 | Garden
Carburetor manufacture for Honda Lawnmowers.
Honda manufactures all their own products in their own factories including the carburetor
Oct 25, 2009 | Garden
2001 Honda Recon does not idle and stalls. Are
First off, check and adjust the valve tappet clearances. Under normal use, the valve tappet clearance tends to decrease. With this comes lost compression and a poor idle.
Next, check the air filter (clean as needed or replace), and drain any water or other sediment from the carburetor float bowl.
Oct 24, 2009 | 2001 Honda CBX 250 TWister
1998 Honda VT 750 C2 Shadow loss of torque
Hi, Funnyslug24 and the usual suspects are:
1. Dirty or clogged air filter.
2. Faulty spark plug.
3. Bad Gas.
4. Improper oil level.
5. Improper chain adjustment and lubrication.
6. Low tire pressure.
7. Dirty or contaminated carburetor needs cleaning and tuning.
8. Clogged or faulty fuel pump or injectors.
9. Improper valve adjustment.
10. Slipping clutch.
11. Improper timing.
12. Low compression.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
loss of power
2000 vt1100c power loss at high rpm
Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Jan 06, 2018 | 1998 Honda VT 750 C2 Shadow
Fuel mixture appears to be too rich on myHonda lawnmower
There is an air/fuel ratio adjustment screw on the side of the carburetor. Turn this back and forth until the mower runs smootly.
May 04, 2009 | Garden
Garden Logo
1,520 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
