Question about GE Profile Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22MIS
GE Profile bottom freezer fridge. An alarm keeps going off and it flashes Lc Er on the display. Also, icemaker quit working but it is still dispensing water. Every once in awhile it spits out a cube or two. Not sure if the two items are related.
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 01, 2011
I have a GE Profile bottom freezer that door alarm will not stop. How do I fix it. I turned off the breaker for 30 minutes, and the alarm was silent when I powered back up, but the started to repeatedly...
Open freezer door. On top You will see 2 or 3 switches. Push all of them, if light in the freezer did not go off - you have bad door switch, if it did go off try same thing with fresh food door. Door switches do go bad once in a while on this fridges. Thanks
Mar 23, 2015 | GE Refrigerators
OUR REFRIGERATOR HAS A ALARM GOING OFF WITH A ERROR CODE LC ER
this sounds like the door alarm- it occurs after the door is open (or the switch has failed) for more than 2 minutes. Remember that both doors have one and also turn on/ off the lights which may or may not be tied together.
May 04, 2014 | GE Profile Stainless Bottom-Freezer...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator knocking noise
If it seems to be coming from underneath the unit it could be the compressor. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That's usually mounts inside the compressor. Usually when the compressor cuts off. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Any other noise would be from a fan. One in the freezer behind the back panel and one under the unit where the compressor is.
Dec 29, 2009 | GE Profile Stainless Bottom-Freezer...
GE fridge PDS22MBSWW - relay clicks on and off
sounds like a main control...check the fans ... unplug each on at a time to check if the relay will stop clicking...
Sep 21, 2009 | GE Profile PDS22MBSWW
I have a PSS26 ge profile fridge and it quit making ice
The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile brita 18 bm black purchased in jan/06
Having the same problem. apparently this is just a horrible fridge... unfortunately no solution for ya
Jan 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
New GE profile bottom freezer fridge intermittent buzzing
If the buzzing is a short (say 5 seconds) every once in a while, it sounds like the water is valve being energized. That would mean the icemaker is turned on and is cycling. Besides the noise, when it cycles it turns on the mold heater, which you do not need if not making ice, and thus is actually adding heat to your freezer, increasing operating cost. Just turn the icemaker off by flipping the toggle switch on the icemaker itself. It is a white switch near the bottom corner of the icemaker. Should be easy to spot.
Oct 11, 2008 | GE Profile PSW26P Stainless Steel Side by...
Display screen says "Er ff"
LG's bottom mounts have had problems with air leaks in freezer making a iceball right under the evaperator fan actually coming close enough to the fan blades to slow them down or stop them all together also causeing the FFerror meaning the control board is not detecting the normal RPM's you should to keep it cool enough. Suggestion take the back panel off and remove any ice carefully if this be the problem. Make sure all doors are closeing tightly and gaskets make a air tight close.
Jan 20, 2008 | LG LFX25960ST Stainless Steel French Door...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22MIS Logo
945 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
