Question about Garden
Mower will not stay running and sputters out. Will not restart immediately and must sit for 1 hr or so. While running sputters and does not seem to run at highest rate. Gas is full no recent changes made. 2 yrs old, minimal use.
  • 718 Answers
Your carb needs a good cleaning. while your at it clean the fuel tank very well empty it totally and blow it out to dry.
Posted on Apr 01, 2011
My car is sputtering and dying. If I try to restart it, it will immediately go into sputtering/dying mode. If I wait a while an hour or so it will start up and drive fine.
When was the last time that the carburetor was stripped and cleaned? Also have you checked the fuel filter? Finally, the problem seems to come and go as the engine is run (and it gets hot) check that the fuel line and any electrical cables are well away from the hot engine as far as is possible.
Jun 16, 2015 | Cars & Trucks
Snowblower was running for 1 hr. i shut it off when i restarted it ran 1 minute and stoped could not get it started, it it sat for 6 hrs. and started but would not run at higher rpms. it seemed to sputter
Hi. And welcome to FixYa. I am Kelly
From the symptoms you describe it sounds like the low oil sensor is shutting of the ignition.
i.e ran for 1 hour... hot oil... / low oil level ignition cut off. Sat for 6 hours all oil now in crankcase... started and higher rpm sputters....
Check the oil level. Other than that I think everything is fine.
If not please respond with a "make and model" of your snowblower. After that, there is more that we can do to resolve the problem.
Thanks for using FixYa!
Kelly
Feb 11, 2010 | Garden
2 year old craftsman 42" deck tractor runs fine for 15 minutes then sputters and dies. Will start, run 2-3 minutes, die again. Leave sit will run for 20 minutes.
if it restarts immediately, check the vent in the gas cap for restriction. also, the solenoid on the bottom of the carburetor may be sticking or getting weak. if you have to let it sit for awhile before it retarts, the ignition module may be breaking down when it heats up. i'd bet on the gas cap or solenoid though
Sep 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My mower starts and runs great when cold but dies when hot. It will restart but won't stay running until it cools off again.
How old is your mower ? Sounds like points and condensor if older model ,or ignition module if its newer , points tend to stick together when they get old causing no spark at plug when they cool they come appart allowing it to spark again , module is sort of the same except you have no way of replacing points you have to replace module .
May 11, 2009 | Garden
Starts but won't stay running
I had the same problem with my Husqvarna. I thought it was the fuel system, but I was told to check my gas cap for proper venilation. When the mower starts to sputter, unscrew the gas cap to let the air flow. If it isn't venting right it will actually pull the gas out of the carb.
May 04, 2009 | Garden
Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
May 01, 2009 | Toro Lawn Mower With Toro Power Tools
Lawn mower dies
Find the fuel air mixture screw and while the mower is running turn so mower almost stops then turn them back till the moter is running smoother.Give it some throtle to see & hear how it is running
Nov 02, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
