Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Msg after entering service mode
Must be an all too common problem, my WPGT9350 is also showing msg. "Motor not rotating properly" replace if necessary.Is this the only way to repair it?Sounds expensive!
Thanks, Catriver
  • 725 Answers
There are 5 solutions for this problem
1) house voltage (voltage to low)
2) Inverter
3) Motor (if motor only turns in one direction)
4) wire connection to the low voltage
5) Hall sensor at rotor (only turns a 20% of speed)
let me know if I can help you more...
Posted on Sep 13, 2008
GE Profile Harmony Washer WPGT9350COWW. Unit says " A problem has been detected with this unit" I went into the self diognostic mode and it said "Motor is not rotating properly" then...
There's no specific way in the self-diagnostics that can confirm which specific part is bad. Actual tests must be done at least with the Hall Sensor and the motor. Please be noted that the wiring connections of the Hall Sensor and the motor with the inverter cannot be ruled out completely. It is prudent to make sure that the connections are tight and snug fit as absence of such can result in intermittent connection problem which will trigger the machine to prompt the "motor not rotating properly" warning.
The test needs to be done with the motor is the winding resistance between any two of its three terminals. The normal winding resistance is around 8 ohms between any two terminals. Any significant discrepancy in the resistance readings renders the motor inoperable and it must be replaced.
Measure between pins 1 (blue) and 4 (yellow) and pins 2 (red) and 4 (yellow) with the Hall sensor plugged into the inverter board. Rotate the spin basket by hand. There should be 12VDC pulses as the basket is rotated. If pulses are present, the Hall sensor is good; otherwise, it must be replaced.
It can safely and surely be concluded that the inverter is bad if both the Hall Sensor and the motor show no problem. If you want to verify, disconnect the Hall sensor plug from the inverter board. Check voltage on pins 3 (brown) and 4 (yellow) on the inverter board. There should be approximately 12VDC. If not, the inverter board is bad and must be replaced.
Please accept the solution should you find it helpful and/or informative. Accepting the solution will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Aug 31, 2011 | GE Washing Machines
Cannot i sent messages from sonny ericson p990i but i can recieve message
ur msg centre number is not specified .....!!!! go to msg settings --->text msg-->msg centre no. and now ask ur service provider to provide u the msg centre no. and enter that no. dere
Feb 15, 2010 | Ericsson Lands Phones
Showing msg contact service
go to any mobile shop ask for flashing .it will charge rs 100/
Jan 27, 2010 | Nokia 5130 Cellular Phone
How can i enter the service center number for txt msg.
Go to message from the menu---->click on the option at the bottom left--->settings---->text message--->service centre (in some older phone--->profile---->default profile).
Nov 12, 2009 | Samsung Cell Phones
Low toner msg stay on
open front cover, press "options" button & press "start" then enter "1" then "0". when display shows accepted, close cover.
hth,
razors
Feb 18, 2009 | Brother IntelliFax-2820 Laser Fax
Machine 'protect' msg
his appears to be a very common problem here on the board. It means the unit has shut off the outputs because of either a bad speaker or shorted wire, or some failed part in the amplifier. If the trouble continues after you disconnect the speakers, the unit will require service to diagnose and replace the failed part(s).
I've never worked on this model, but in many brands the amplifier integrated circuit is a common failure. They are often not properly mounted for efficient cooling and burn themselves out. Another typical failure is some power supply part that is under-rated and just goes bad, and this is showing up as the protect failure.
Without a diagram and no direct experience, I can't suggest any specific action you could take, other than checking with a local shop for a repair estimate. (You might try contacting JVC on their website or by phone to see if they have any service bulletins. If something becomes a chronic issue, the manufacturer sometimes extends warranty service to cover the repair. Never hurts to ask!)
Feb 12, 2009 | JVC MX-KA3 CD Shelf System
'PROTECT' MSG EVERYTIME TRYING TO OPERATE
This appears to be a very common problem here on the board. It means the unit has shut off the outputs because of either a bad speaker or shorted wire, or some failed part in the amplifier. If the trouble continues after you disconnect the speakers, the unit will require service to diagnose and replace the failed part(s).
Display - wont work properly
Have you checked voicemail? Do you have any new messages?
Dec 02, 2008 | NorStar M7310 Corded Phone
Mms message download
that usually means the phone does not support the picture file that you are trying to open
Oct 08, 2008 | Motorola Mobility RAZR V3
Ricoh CL7200D Replace Fusing Unit (type C)
press the two arrow for 10 sec. hit enter you are in service mode
go to engine and diagnostic1 and sp7804 and go to 16
reset fuser change. enter
Jun 05, 2008 | Ricoh Aficio CL7200D Laser Printer
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
299 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
