Question about Vivotek Ip7139 Hi Res Wireless Ip Cctv Security Camera
I have a sentient wireless hi-res CCTV kit but can only get a black & white picture and no sound? Have I plugged it in wrong?
Hi have sentient cctv hard drive but the power light his flashing no pictures on screen
Check the monitor first to be sure it has not failed. Use another monitor or a flashlight against the screen of the one you have to verify there is no image.
Feb 18, 2017 | HIS Computers & Internet
Sentient cctv support
You may have to do an online search for one of several suppliers of OEM remotes.
Sep 06, 2014 | Televison & Video
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
I changed the admin password on my sentient cctv dvr from the default 123456. I saved the changes but now get the message incorrect password when I input the six digit password I stored. Please help
Hello
After system boot-up, hold a right mouse click
button and there will be login window. Hold a left
mouse button to click the order of "Account", and
input correct account. Then left click the order of
"Password" and input correct password. At last
left click "Login" to enter system. There is one
factory-preset login "account/password"
"admin/111111" at admin level. The user can
use it to login the system for the first time
May 22, 2011 | Ganz DR4NC-160 DVR DIGITAL VIDEO RECORDER...
Sentient 250GB DVR-RW CCTV N63HH - recording for longer peroids
Just reduce the frame rate slightly on each camera or the record quality and it will increase the data retention period.
Jun 14, 2010 | Dome 4 CCD CCTV Camera Surveillance...
Cannot delete events from Sentient N663HH 4 camera DVR system.
go to hard drive setup
you will need to overwrite over it.
go to overwrite on your set up and select yesto enable to overwrite harddrive when capacity is full
May 20, 2010 | Cameras
I have a sentient CCTV Hard drive recorder. Was working, but now shows no picture on the monitor. Power supply light on but does not work.
Unfortunately it is past DIY stage. Consult a service center.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 05, 2010 | Home Security
Sentient dvr cctv playback
Hi, I have a maplins sentient model Sentient dvr cctv is there a windows 7 PCviewer programe ?
Mar 30, 2010 | Computers & Internet
Panasonic TH-42PD25 The picture is black with
Make sure if your using the video input jacks, that the yellow is plugged into Video 1 and the same with the audio.Red & White. If your using Component, they are color coded- Red Blue & Green along with the Audio In -Red & White. It sounds like you have the video in the wrong jack.
Oct 28, 2009 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Need wireing map for cv67 i have four wires red black yellow white whats what?
Only red(+) Black(-) and Yellow (Video) is used if you just cut off that mini din plug end and were looking at the wires coming from camera. I bought some standard power and bnc pigtails from DX.com and replaced that mini din cable they use to make their connections to a standard cctv type.
Un-screw the main lens cover and you will see a screw ring and by taking a verner caliper to catch on both sides you can unscrew camera unit ring and when you look inside the only wires you need to solder to new pigtail is red/black/yellow each to their own color.
Pushing the pigtail thru may be a little pain but with a little spit on wire makes it a lot easy.
Re-assemble in reverse and you should be up and running.
Camera runs on 12 volt with center of plug positive and video bnc center is video.
Hope this helps.
Sep 28, 2009 | SVAT CV67 Hi-Res Outdoor Weatherproof...
Vivotek Ip7139 Hi Res Wireless Ip Cctv Security Camera Logo
227 people viewed this question
Top Vivotek Home Security Experts
Lawrence Oravetz
Are you a Vivotek Home Security Expert? Answer questions, earn points and help others
