Question about Car Audio & Video
2000 mercedes clk bent frame report in accident, can it be repaired, and how much cost.
  • 28 Answers
It can be repaired and its cost will depend wether u made it repaired by company or by any local person
Posted on Mar 31, 2011
I have a bent rear passenger side tire due to an accident, how do I fix it?
sounds like a hard hit ur problems can be an accumulation of one or more of the following bent rim --,bent and or broken hub,-- spindle bent or broken,shock,strut bent,broken--unibody [frame]bent ---u will have to remove wheel and look at the parts and see which is damaged also open trunk and look at the floor for bends and wrinkles also look at rear from back and look at the body for straightness unless u have a straightener for the unibody to fix body and or frame should be done by shop that is trained in repairs r the parts which ever part or parts need to be replaced they are all bolt in only worry would be replacing the strut if ur chevy came with that option most had a shock
May 21, 2012 | 2000 Chevrolet Cavalier
I was testing the wires for the left side parking light to see which one was the ground and which one was the positive, i accidently made a connection, there was a spark and now the park lights for the...
Can be an internal main frame issue...all fuses are good? Try an go over fuses and connections once more to verify. Worst comes to worst...Mercedes dealership would probably be your best bet.
Apr 20, 2011 | 2000 Mercedes-Benz CLK
Where can I get chassis drawings or repair manual for my CLK 320 Elegance Cabriolet model 2000? I need to uninstall the radio system for upgrade.
all you need is the radio keys to remove the radio. If the radio has two little slots in the bottom corners is the way to tell if thats all you need. Any good Mercedes repair shop should have the radio keys and should be able to pull it out for you at no charge. It only takes seconds to do.
Oct 23, 2010 | 2000 Mercedes-Benz CLK
Hello had a motorcycle accident. He collided with the stone fence. motorcycle speed was not significant. the garage will tell you that he not be kept as body rolls. It can be or not?
Trust the garage. I am sure the forks are bent and chances are the frame is twisted as well. The cost to repair the bike will be more than the bike is worth.
Sep 07, 2010 | 2000 Yamaha YZF-R6
How do i locate and remove fuel pump on a mercedes clk 200k and is it a easy repair
its inside the fuel tank and yes it is easy with the right tools ,mainly the special wrench to undo the sender unit where the pump is underneath
Jul 16, 2010 | 2000 Mercedes-Benz CLK
Haw repleace airbag module in mercedes clk 2000 ! where is located !
the module is part of air bag /front steering wheel module for example is attached to a/b and is part of mounting platform in steering wheel--- also which one--
Oct 23, 2009 | 2000 Mercedes-Benz CLK
Mercedes CLK Exhaust problem
hi, the problem you are having sounds like the exhaust hasnt been ligned up properly when it has been fitted.
Or it could even be that the rubbers the exhaust rests on could be worn and need replacing.
If you hold the end of your exhaust at the back of the car give it a shake and see how tight it is, their should only be slight left to right movement if their is alot of movement then get the rubbers looked at. If their is only slight movement then the chances are the exhaust has not been lined up properly when it was fitted.
If your car had no problem before then the chances are it is the exhaust so i would check its ligned up and also check all the exhaust mounts are in place and that the rubber clamps holding the exhaust to the car are not worn as to much wear can cause the exhaust to vibrate.
One other thing to look at is the heat shield just above the exhaust if this has been bent then this could be touching your exhaust slightly causing the vibration this can be bent back so it is not touching the exhaust.
Let me know how you get on or if you need further assistance ok
Aug 22, 2009 | 2000 Mercedes-Benz CLK
Do mercedes cars registered in 1999 have a 10 year rust warranty
yes as far as i am aware they had a 30 year warrantee and changed it to 10 year (makes sense) was told this by merc owner (dad)
Jun 16, 2009 | 1999 Mercedes-Benz CLK
2000 320 clk--outside temp light is out...how do I replace it?
is the digits on the dash like 1.0 or is there no digits if there is no digits you need to send your speedo dash to speedo fixer it cost me £150.00 my clock and temp digits went off and had it repaired by this company can highly recommed them
Dec 29, 2008 | 2000 Mercedes-Benz CLK
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
