Question about Microsoft Windows XP Professional for PC
When i click on any application i get an error open with how can i reoslve this?
    President:
  • 2,992 Answers
Without seeing the exact text of the error message I can't tell you for sure what's wrong, but you might have a malware problem. Many of the fake anti-virus programs that can infect your computer will make it behave this way. Any application you try to run results in a message that it can't start because it's infected. And you may be getting "virus scan" windows popping up telling you all the bad viruses it's finding, and telling you need to activate your virus protection. It's all a scam and the only bad software is that program itself.
Download and install the free version of MalwareByte's Anti-Malware. Restart your computer in "safe mode with networing". This will keep the infected program from running so that MBAM can run. Let it update and do a quick scan, have it correct any problems it finds, and this should clear up the trouble.
Posted on Mar 31, 2011
I want to have email ID on hotmail
Just click here and fill out all of the information required: https://signup.live.com/hmnewuser.aspx?m… Please post your feedback and Vote if the problem reoslved as per your satisfaction.
Jul 02, 2010 | Computers & Internet
Blackberry 7290 device error 400 how solve this problem
When adding, deleting, or updating applications on your BlackBerry smartphone, your BlackBerry device resets itself and stops responding.You receive the following error message:
Device error 400
  1. Disconnect your Blackberry smartphone from your computer.
  2. Open BlackBerry Desktop Manager.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
Nov 01, 2009 | RIM BlackBerry 7290
My blackberry 7290 gives error 507 with a circle at the top
You will receive the following Java error 507 message on your BlackBerry smartphone while using the application loader tool to install or upgrade the BlackBerry Device Software.
Cause 1:
This might occurs while using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
To resolve this error you need to complete the following steps:
  1. Verify that you have the BlackBerry Device Software installed on your computer.
  2. If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
  4. If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
  5. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  6. Use the application loader tool to install the BlackBerry Device Software.
Cause 2
This might occurs while all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
  1. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  2. Use the application loader tool to install the BlackBerry Device Software.
Cause 3:
This might occurs while the Power Management feature on the computer turns off the USB ports.
  1. On your computer, click Start > Settings > Control Panel.
  2. In the Control Panel, double-click the System icon. The System Properties window opens.
  3. Click the Hardware tab of the System Properties, and click Device Manager.
  4. In the Device Manager, double-click Universal Serial Bus Controllers.
  5. Right-click the first USB root hub, and click Properties.
  6. In the Properties window, click the Power Management tab.
  7. Clear the Allow the computer to turn off this device to save power check box.
  8. Repeat steps 5 to 7 for all other USB root hubs.
  9. Restart your computer.
Cause 4:
This might occurs while the BlackBerry smartphone is connected to a laptop computer using a docking station.
  1. Disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer using a USB cable.
  2. Re-install the BlackBerry Device Software using the application loader tool.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Oct 21, 2009 | RIM BlackBerry 7290
BB messenger error "Uncaught Exception: java.lang.null...
When attempting to send messages from the BlackBerry device, the BlackBerry device user receives the following Java error called uncaught exception java.lang.illegal argument exception:
To over come this error you need to complete the following steps:
First, perform a full backup of the BlackBerry device data:
  1. Connect the BlackBerry device to the computer using the USB cable.
  2. Open BlackBerry Desktop Manager, and then double-click Backup and Restore.
  3. Click Backup.
  4. Save the backup file.
Run the application loader tool and erase all data on the BlackBerry device:
  1. In BlackBerry Desktop Manager, double-click Application Loader.
  2. Click Next.
  3. On the Device Security Password screen, type the BlackBerry device security password, and then click Next.
  4. On the Device Application Selection screen, click Next.
  5. On the Completing the Application Loader Wizard screen, click Advanced. The Device Data Preservation screen is displayed.
  6. Select the Erase all application data check box, and then click Next.
  7. Select Do not automatically back up and restore the device application data during the loading process, and then click Next.
  8. Click Finish. The BlackBerry device resets. This might take several minutes.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 20, 2009 | RIM BlackBerry 8800
I have a blackberry 8130 and the app 523 error coming up how to fix it
On the BlackBerry smartphone, the following error message appears "app 523 error" after pressing the Mute button, accessing an application, or performing a hard reset.
To resolve this issue, the BlackBerry Device software will have to be reloaded.
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Add/Remove Applications.
  4. Type your BlackBerry smartphone password and click OK.
  5. Select the check boxes next to the names of the applications you want to load.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Click OK.
  8. Click Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
Jul 12, 2009 | RIM BlackBerry Pearl 8100
My phone has an error that say device error 400 reset. it wont even let me use it or nothing
When adding, deleting, or updating applications on your BlackBerry smartphone, you receive the following error message:
Device error 400
OR
CAUSE
An unspecified error has occurred with an application on your Blackberry smartphone.
RESOLUTION
NOTE:The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
  6. Click Next.
Jun 11, 2009 | RIM BlackBerry 7290
I get this: App error 205 / reset - Hour glass keeps running. I removed the battery several times.
If it is application error then follow these steps: Warning: You should not install a version of BlackBerry Device Software that is earlier than the version installed on the BlackBerry smartphone. Doing so could cause the BlackBerry smartphone to malfunction. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the computer by completing the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then select the check boxes beside Erase all application data and Erase all currently installed applications . Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager Note: BlackBerry Desktop Manager 4.3 will display the Delete all application data and Delete all currently installed applications check boxes in step 6 of the above procedure. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Add/Remove Applications. Type your BlackBerry smartphone password and click OK. Select the check boxes next to the names of the applications you want to load. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Click OK. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager. Note: The Delete all application data and Delete all currently installed applications options are not available when using the Application Loader in BlackBerry Desktop Manager 4.5. A workaround for this issue is to use the Application Loader standalone file by performing the following steps: Open My Computer (or Computer in Windows® Vista?). Navigate to C:\Program Files\Common Files\Research In Motion\AppLoader. Run the Loader.exe file and follow steps 3 through 9 above to complete a clean installation of the BlackBerry Device Software.
May 26, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Reload software 513 error
After typing an incorrect password ten times and restarting the BlackBerry smartphone, the following error appears:JVM 513
All of the data and applications on the BlackBerry smartphone have been deleted and The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone (Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader)
1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2) Double-click Application Loader.
3) Click Add/Remove Applications.
4) Type your BlackBerry smartphone password and click OK.
5) Select the check boxes next to the names of the applications you want to load.
6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
7) Click OK.
8) Click Next > Finish
9) When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
Apr 10, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Blackberry device error 411. I also had a strange
Before Perfoming these steps take a Back up of your Handset. Cause 1 The wireless transceiver software was not loaded onto the BlackBerry device correctly. Resolution Re-install the BlackBerry Device Software using BlackBerry Application Loader. Connect the BlackBerry device to your computer. Open BlackBerry Desktop Manager and double-clickApplication Loader. The BlackBerry Application Loader Wizard opens. Click Next. If prompted, enter your BlackBerry device password and clickNext. The Application Loader Wizard examines your BlackBerry device?s current configuration. When it is finished, the Application Selection window appears. Select the applications to be loaded on to the BlackBerry device and click Next. The Completing the Application Loader Wizard screen appears. Do not click Finish. Click Advanced to begin loading the applications. In the Data Preservation window, select the Erase all currently installed applications check box and clickNext. In the Application Data Backup window, choose the option to automatically back up the application data before loading and to restore the contents when the load is complete. Click Finish to begin the BlackBerry Application Loader process. Click Close when the loading operation is complete. Cause 2 There is a wireless transceiver hardware failure. Resolution Contact your service provider for more information.
Mar 24, 2009 | RIM BlackBerry 7290 Smartphone
Microsoft Windows XP Professional for PC Logo
54 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
