I have ammonia system for apartment units and need to remove how would I drain ammonia for disposal of unit
    Genius:
  • 1,400 Answers
Hello
First you will need face and hand and eye protection.Possibly a air pack.
The best way and safe way is to drain the ammonia into a 5 gallon bucket filled half with water.If you have a steel braided hose its best to use it.Ammonia will burn through rubber.
Water will neutralize the smell,watch out for pockets of oil,thick brown syurp like coming out.
Once the oil comes out the ammonia is going to come out violently.Let a little out a a time.
Try not to inhale the fumes,if the smell gets to sronng dump the water and get fresh water.Im not sure of the area your working in but running a water hose over the unit while you drain it will help if you can.
Posted on Mar 31, 2011
  • mpcheesman1
    mpcheesman1 Mar 31, 2011
    Drain from the liquid side or high side.Not the suction side of the system.
Getting Rid of Disposer Smell
Remove and clean trap underneath sink.
Then flush disposal and tubular drain with hydrogen peroxide
May 23, 2012 | Electrical Supplies
The unit works, but if the water level gets too high, while operating, it begins to drip from the bottom of the unit. Nothing on the exterior is wet. Can it be fixed, or should I replace it? Where can I...
Where is leak coming from?
From the pipes or from bottom of disposal?
If leak is coming from tubular drain pipe or around dishwasher connection, then clean out disposal and repair connections.
If leak is at bottom of disposal, then disposal is probably rusted out and needs replacement.
To solve high water issue and leaking pipes.
Loosen 2 nuts on P-trap and trap falls loose. Then remove tailpiece that connects to side of disposal. Hang rag over opening on side of disposal so water is directed downward, then turn on water and disposal and flush out the clog. Clean trap and tubular drain, and then reassemble.
I wrote ez disposal replacement steps, that also show how to take apart and reassemble tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
BADGER DISPOSAL UNIT 5-81 SEEMS TO WORK, IT'S NOT STUCK BUT THE WATER WON'T GO DOWN IN THE SINK. ANY SUGGESTIONS.
Clean out the p-trap and tubular drain under the sink:
I wrote ez disposal replacement steps that cover how to take apart tubular drain pipe and put it back.
Jun 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My badger 5 plus 5/8 HP HD insinkerator is leaking from the bottom of the unit. It is dripping from the reset button and one other metal tab location. It is at least 10 years old. Can it be repared?
Sorry to read about your problem, I hope this helps you out.
sorry no it is rusted out, even if you could take apart, after 10 years 1/2 the parts will be rusted..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.
Thanks and good luck. you are looking around $90.00 for a new unit
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ammonia smell from rv refrigerator. Not working.
i suggest u take ur rv ammonia refrigerator to ur rv dealer for a replace.. ammonia leaking can result in serious injuries, in tight places...
Jul 01, 2010 | Dometic RM2620 Refrigerator
Motor comes on; but does not cut the waste. Water
The water staying in the unit suggests the drain is clogged. Usually this happens outside the disposal, at the T-junction in the drain lines. Unless your plumbing is *very* old, the drain lines should be PVC with large nuts that can be removed by hand.
Use a bucket below the junction as you take things apart to catch the water. Keep in mind that below each nut, inside the joint, there is typically a translucent washer (triangular cross section) around the pipe - don't lose this, or your joints will leak when reassembled.
This job isn't tough, but it is messy. If you have any doubts about reassembly, take photos before taking things apart, so you have a guide to work from.
Nov 26, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Maytag Quiet Series 100 Help - diswasher always has water in the bottom - doesn't fully drain. We took apart as far as we could down to the hole with the orange washer _ no obstruction. Put it back...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 03, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Water not draining kenmore dishwasher
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 20, 2009 | Electrolux Kenmore 24 in. Built-In...
Leaking sinkmaster 850 garbage disposal
I have had these apart. The leak is from a seal around the motor shaft. By the time it is leaking the shaft has pitted to the point a new seal will not repair it. Getting it apart can result in damaged parts as it is sealed together with very tight tolerances and a glue like sealer.
Eric
Jul 02, 2009 | Food Processors
Our Badger garbage disposal is filled with water, won't empty out, just keeps running and spinning water around in the sink. We've tried the reset button, unplugging and plugging back in and a plunger. Any...
Sounds like the unit is fine but I think you have a plugged drain.Put an empty bucket under the trap and take it apart.Next remove the tailpiece from the disposal and clean it out.If everything is clean and you can't find the clog you will need a drain snake to remove the clog in the drain pipe.Good luck.
May 11, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
