Question about Sewing Machines
I have a Janome 6260 sewing machine and the bobbin casing keeps shifting and the thread then gets caught and the whole machine seizes. I can move the bobbin casing around and release the thread and the machine will work for a period of time and then suddenly jam. Any suggestions as to why the bobbin casing is moving and the little black rubber that is on the side of the casing actually jams against the silver box in the bottem right corner. Thanks
  • 29 Answers
SOURCE: a horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
Posted on Jul 14, 2007
SOURCE: Euro-Pro Shark Intelli-Sew 9110
you need a new bobbin case, only problem is finding the right one. I am currently wasting hours trying to find one for our 9110 intelli sew which has needle holes punched through it from where it jumps right out. I think lots of manufacturers know fine which parts fit the Euro-Pro but would like all of us to scrap them and go out and buy theirs!
Posted on Sep 18, 2008
  • 76 Answers
SOURCE: Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Posted on Sep 03, 2009
  • 980 Answers
SOURCE: Touch & Sew zig-zag model 758 - bobbin thread
email me for retiming instructions and remind me of your make,
Posted on Jan 09, 2010
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Posted on Mar 21, 2010
My janome sew mini sewing machine is very slow can I fix it
First clean it thoroughly bobbin case included then oil it according the owners manual, i hope it be ok because the thread got caught in bobbin case and lint that causes it slow down.
Sep 25, 2014 | Janome Sewing Machines
here is a link for a manual --it should have how to put the bobbin case in Instruction Manual Janome 6260
May 07, 2014 | Brother CS-8150 Computerized Sewing...
Showing E6
You receive the error message E6 when the motor locked up because thread is tangled or the machine is seizing up.
Remove the tangled thread, it it still happens that means your machine is seizing and requires service.
Apr 30, 2014 | Brother CS-8060 Computerized Sewing...
Have Janome DC3050. Bobbin thread is getting caught on the hook shaped guard to the right of the bobbin. Hook race? I know threads got caught in bobbin and believe it bent or moved this. Now makes a...
I don't know your model but my Janome 6500 has a bobbin case held in by magnet on the underside and it will dislodge and move if there is a jam up. This then prevents it from forming stitches correctly. You need to lift out the bobbin case and put it back into position. With mine, when it has moved, the needle then strikes part of the case when it comes down. This often results in a burr in the plastic which then causes the thread to catch again even when the case is back in correct position.
There should be two marks, one on the case and one on the outside to align it to.
this is my bobbin case, and the cut away part on lower part of the image is the bit that goes into the machine away from you.
Feb 07, 2014 | Janome DC3050 Computerized Sewing Machine
The needle thread keeps getting caught as the bobbin thread is brought up initially and again as I sew. It has been looked at by repairmen but no solution has been found. Should I replace the bobbin...
The bobbin might not be in the case just right, or the case not in the machine just right.
Remove the bobbin case and make sure the thread from the bobbin is feeding from the spool in a clock wise direction and through the guide on the side of the bobbin case.
Raise the needle to it's highest position and this will move the shuttle to it's proper position.
Lift the lever on the back of the bobbin case, with the arm on the case pointing toward the ceiling and slip into the shuttle.
Bend your head down and you will see the shuttle has a slot for the arm to fit into.
Once you get the feel for this you will not have to bend down for a bird's eye view!
Always thread a sewing machine with the presser foot up. Make sure the threading sequence is correct and the thread has not slipped out of the take up lever.
Hold onto the top thead end and lower then raise the needle to pull up the bobbin thread. Pull both threads under the presser foot and to the back of the machine.
You should now be able to sew without any issues.
Jul 14, 2011 | Janome Memory Craft 4000 Sewing Machine
The thread gets caught in the bobbin case area and does not for a stitch and becomes entanged.
check your needle to see if it's damaged
some sewing machines jam in the bobbin area when the thread comes off the thread take up lever
check the bobbin & bobbin case for burrs
Sep 23, 2010 | Janome Sewing Machines
Thread is knotting up under the feed dog plate getting error LO.I tried removing the plateand cleaning and replaced bobbinholder and it is still jamming. is there supposed to be any play in the bobin...
It should move a little so the thread has clearence. If the thread is bunching underneath, it usually means the thread's not in the take-up lever or top tension is too loose. If you're needle has hit the bobbin case and created needle marks, the thread can get caught... in which you'd need to replaced the bobbin case.
Feb 23, 2010 | Janome 8080 Computerized Sewing Machine
The thread keeps getting caught in the bobbin area.
Turn the bobbin around in the case so that the bobbin turns in the same direction as the thread is flowing. If you pull the thread in the case and the bobbin turns opposite the flow of the thread then you might have a problem.
Make sure the shuttle is in place, you will have to look at the manual for this. Replace the case and bobbin. Make sure you have a good needle in place.
Aug 10, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
60 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
