Question about JVC MiniNote XP731 (MP-XP731) PC Notebook
JVC XP731MP 2 Maschines same problem. After press "ON" the question "Press F10 to recover" If I recover, maby the System (XP) work for a wile. But not long. Break down to selftest, then boot again then "Press F10" again. and so on. Do you have any solution? Regards
3 Suggested Answers
  • 2318 Answers
SOURCE: Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Posted on Apr 10, 2008
SOURCE: jvc hxd7 system problem
mine does the same took it apart and there is a hole burnt through the audio output board (AH41-00836A) cant find the board if I do think it would be better to buy new system
Posted on Feb 24, 2009
Windows xp hard reset
This is what you manual said to do, unfortunately most times the Recovery does not work. I prefer a clean install over recover because I don't get all the unwanted programs.
Instructions from Manual below:
Turn off the computer. If necessary, press and hold
the On button until the computer turns off.
2 Disconnect all peripheral devices from the
computer, except the monitor, keyboard, and
mouse.
3 Press the On button to turn on the computer.
4 Immediately, when you see the initial company
logo screen appear, press the F11 key on your
keyboard repeatedly until the Recovery Manager
window appears.
5 Click Advanced options.
6 In the Advanced options window, click System
recovery, and then Next.
7 Click No to back up files (if you have already
done so), and then click Next.
System recovery begins. After system recovery is
complete, the computer restarts.
Have you tried doing a System Restore to a restore point (date and time) before you started having problems?
A clean fresh install of windows might be your only and best option.
Apr 24, 2012 | HP Pavilion a6228x PC Desktop
Tip
Three simple ways to recover Windows XP password
<p><a><span>This may happen when you attempt to log in to your Windows XP and you realize you lost the password. Just because you can't remember or some hackers had change your password.</SPAN></A><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>It's easy to gain access to Windows after losing user account password. Just simply login as the computer administrator and go to control panel-&gt;user accounts. There you will be able to reset the password for any of the systems user accounts.</SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>Howerver, things will get more tricky if you have <b>lost Windows administrator password</B>. It's a sickening,powerless feeling to be locked out of your own computer though this happens more often,everytime we feel so helpless.What should you do in facing this situation.You have tried everything you could but failed.</SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><a><span>This problem of<b> Windows XP password recovery </B>often troubles most PC users, especially for those who have little computer skills. For this, </SPAN></A><a><span><span>following are three simple ways on how to </SPAN></SPAN></A></SPAN><a href="http://www.lostwindowspassword.com/"><span><span><span><b><span><span> </SPAN>recover Widows XP password</SPAN></B></SPAN></SPAN></SPAN><span><span><span></SPAN></SPAN></SPAN></A><span><span><span><span> to help you login your computer again.</SPAN></SPAN></SPAN></SPAN><br><span></SPAN><span></SPAN> <p><span><span> </SPAN></SPAN><br> <p><span><b><span>Method 1:<span> </SPAN>Login as Safe Mode</SPAN></B></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>Start system and press F8 key when Windows is starting up. Then select Safe Mode with Command Prompt and enter. Choose Administrator,the default password may be blank if you don't set the default administrator password before.Then you will enter into doc Command as following.</SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>Type " net user net user xxx 12345 /add " (xxx is the locked account name and 123456 is the new password set on this account).Then you will see the Command Completed Successfully.</SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><b><span>Method 2: Using A password reset disk</SPAN></B></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>Windows XP and further versions also provide another method to recover forgotten password by using ""Reset Disk"". If you created a Password Reset Disk in past, you can use that disk to</SPAN></SPAN><a href="http://www.lostwindowspassword.com/"><span><b><span> recover Windows XP password</SPAN></B></SPAN><span></SPAN></A><span><span> as follows. </SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>Step 1: Start Windows and click your username when you get to the Windows XP logon screen. Type the password wrongly.</SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>Step 2. Press Enter and you will see the error message about "Did you forgot your password?</SPAN></SPAN><span><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: &#23435;&#20307;; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman
on Jan 04, 2011 | Computers & Internet
Have a new Computer, lost disc; need disc to reinstall, Any Sugg??
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to also you could get the serial number if you dont already have it and use it to download the cd from the correct site ie:microsoft , apple , mac
http://www.giveawayoftheday.com/freeware/dir/57858/Download-SoftKey-Revealer.htm
SoftKey Revealer retrieves the CD-Key and Serial for installed softwares on computer. It also saves your money and time, free and easy to use.
Features:
- Recover Windows 95/98/ME/2000/XP/2003/Vista/7 32-bit(x86) product keys
- Recover Microsoft Office XP/2003/2007 product keys
- Recover over 700 softwares product keys
- Save to Text or Word (Word XP and above)
- Print
- Multi language
(Dutch, English, French, German, Italian, Polish, Portuguese(Brasil-Portugal), Spanish, Turkish
hope this helps you
hope this will help
Sep 02, 2011 | Computers & Internet
Every time i boot my computer it freezes and below the screen there is this " verifying DMI pool data, Update success, Boot from CD" what should i do with this problem?
Hi. You need to reinstall again your operating system windows xp.
power on your PC then press F2 or DEL to see BIOS SETTING need your first boot is CD or DVD-ROM press F10 to save and exit. insert your windows xp installer CD.if you see "BOOT FROM CD" press enter. windows xp begin installation please read instruction carefully.very easy understand
to restore your recent desktop.press R.
Jun 04, 2011 | Microsoft Windows XP Professional
Recovery system corrupted failed to recover from factory default settings
if u r using xp then take xp bootable cd insert it and let it boot the system and ther it will sow u the options 1 if u want to install the xp on harddrive then press enter
2 if u want to repair then press R
press r let it lode the required file then select the drive on which u have installed the xp exemple
c: then type command chkdsk /r or chkdsk /f it start recovering the files
or eles u can go to start- all programes- accesseries-system tools-systemrestore- then select option restore my system to earlier time and then click on next then it will sow you the callender select the earlier date then click ok tab it will try to recover ur system
Mar 13, 2011 | Computers & Internet
I have installed Windows 7 to my Acer Aspire One AOD255 but i want to revert it back to Windows XP and I no longer have the Windows.old folder. How can i downgrade it back?
If it originally came with Windows XP and it has the recovery partition still untouched (assuming the disk hadn't been formated to only one partition), you might recover the system from the hidden recovery partition.
To initiate this process, switch on the laptop and press F10 when the ACER logo appears (some computers need you to press ALT and F10 together, instead of the F10 only. If the Acer Recovery Management starts, you just have to follow the instructions to recover your system.
If nothing happens after pressing F10 or ALT and F10, you will need to get a Windows XP installation CD and a external CD drive to reinstall the whole system.
In this case, first you have to enter setup by pressing F2 at boot time, as soon as the ACER logo appears in the screen. Then, you will need to switch the SATA Mode to IDE from AHCI.
Select: Main -> SATA Mode -> IDE
This is done to allow Window XP to see your SATA.as an IDE disk and install the system.
When you get the external USB CD/DVD driver to use with a Windows XP installer CD, connect it to you laptop, switch it on and press F2 again to enter Setup.
This time, scroll over to the BOOT menu and press Enter. Scroll down to the last option USB CD- Rom and then use the F5 key to move it to the top of the boot list order. Then press Escape and then F10 and finally Enter. The computer will restart and load the CD and you can start the installation of Windows XP.
Hope this info may help you!
Mar 13, 2011 | Acer Aspire One D255-1549 Atom N550...
Have a friend that can't boot his computer to windows xp
Before trying to use any of Dell-net's suggestions, we've got to get you into the bios.
It looks generally like this:
You should see a message displayed when you start the computer that says press "Del or F2 or F10" to enter setup.
Once we get here, we can proceed.
Mar 10, 2009 | Compaq Presario 3045US Notebook
I have misplaced the recovery CD for Sharp Actius RD3D PC Notebook and I need to re-install the Operating System, so I requires Drivers for its hardware components, Also if possible an another official...
You do not need the CD to recover this laptop.
From the User Manual:
1. Turn on your computer. When the message <F2> to enter System Configuration
Utility appears on the bottom left of the screen, press F2. Then, the Setup Utility
will open.
2. In the Exit menu, select Load Setup Defaults; then, press Enter twice.
3. In the Exit menu, confirm Exit Saving Changes is highlighted and press Enter
twice.
4. The system will restart. When the message Press F10 to Recover appears on the
screen, press F10.
5. Read the message on the screen, and select the way to recover your system; then,
press Enter. If you selected Formats hard disk and creates new partition, go to
the next step. Otherwise, go to Step 10.
6. Select the volume of C: drive and press Enter.
7. Read the message and select Continue; then, press Enter. The formatting and reinstallation
will start.
Although the pointer may be shown on the screen, never touch the
keyboard or the mouse during recovery except when the message prompts
you to. If you touch them, the re-installation will be canceled.
8. When the re-installation process is completed, the system will restart
automatically.
9. Set up Windows XP by following the on-screen instructions. When you complete
the Windows setup, make sure to set date and time.
If you need help understanding these instructions, feel free to ask.
Jan 08, 2009 | Sharp Actius RD3D Notebook
Laptop system
Hi
Well this is a problem if you didn't make a factory disk nor backed up the system configurations then only thing that will work is to reinstall the operating system. Here is a trick that Acer will never tell you
press the on button and imedetly press ALT + F10 in this order ALT + F10 - ALT + F10 until it goes into recovery mode all the Acers that has 2 partitions have the recovery mode then click on recover to factory defult this will load the factory operating system + driversand applications
kind regards  Mervinh
Sep 22, 2008 | Acer Aspire 5315 Notebook
JVC MiniNote XP731 (MP-XP731) PC Notebook Logo
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tre Elkins
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
