Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
Temp Fluctuations Owned for about 9 months. Every few weeks, sometimes both, sometimes just freezer or fridge temperature shoots up by 10 to 16 degrees. A few hours later its back to normal. No codes and everything else works just fine. thx John
    President:
  • Kenmore Master
  • 2,651 Answers
I wouldnt worry mucha bout the fluxuations in temp, chances are simply a momentary reading perhaps just after a defrost cycle, sometimes new electronics can be a little too sensitive, I would only worry if you actually experience a noticable deiifeence in temp(ie.. your milk doesnt last as long, ice cream not hard as once was,, dairy usually best indicator in temp flux's))) dont worry so much abou the number, unlkess they are consistantly rising without correction
Posted on Aug 07, 2008
I would like to know the correct setting for the fridge and freezer
Setting? Most fridge/freezers have a crude system of setting the temp. and this seems to be dependent upon ambient. For a few pennies they could set the temp. accurately. However, but most peeps just turn it up/down until it's "about right"
The temp. for your freezer will depend upon the length of time that you wish to keep things. Check out freezer stars online. However they tend to have pre-set temp.
For the fridge, this will depend upon what you want to keep in it. but usually 4C is pretty good. You need to get a thermometer, put it in a glass of water (this irons out fluctuations). And check it after an hour. Adjust a little and check again. Repeat until happy.
Note that a cold room can prevent a fridge operating, so be aware of this.
Oct 28, 2017 | Refrigerators
SAMSUNG REFRIGERATOR MODEL RT72KBSL1/2012, IS HAVING TEMPERATURE FLUCTUATIONS. for ex, temp reaches -20 than decreases to 9 degree n again -20 n vice versa. There is fluctuations also on display.
Sounds like your thermostat is sticking on and needs replaced. Before replacing check the setting on the thermostat. Almost all themostats are calibrated to maintain the proper temperature in the correct range when the thermostat is set to the mid position. If your thermostat is number 1 to 9, place it at 5. Refrigerator and freezer do not cool faster setting the controls to the coldest setting. This is misconception of a lot of people.
Sep 29, 2014 | Refrigerators
Rangemaster sxs u109100 fridge freezer temp in fridge +15
Hi - can't solve it but ours has started doing the same - ours will only work if the fridge temperature is selected to 9 C (press the button under ~Ref Temp until cycles round to 9C) then it controls to 9 - if the temperature is set to 5C then it seems to give up and goes back to 15 - don't know why but will investigate more
Jan 17, 2010 | Refrigerators
Bottom freezer temperature rises as high as 35 degrees and drops only to a low of 15 degrees continually. ongoing for a month now. french doors fridge now has temp. fluxes within this past week. temp. goes...
check the defrost thermostat , and any temp sensor that can determine the freezer temperature.
If this fridge temperature is electronically controlled, the freezer control board must also be tested.
Click here to get all parts and diagrams for this fridge.
Regards.
Jul 09, 2009 | GE Profile PFS22MBW French Door...
Fidge beeps and warning door open comes on, temp fluctuates
I had this exact same problem. I replaced the PCB on the freezer. Cost approximately $100.00. Problem solved. No flashing door light, no fluctuations in temperature. YAY.
Jan 26, 2009 | Refrigerators
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
WHIRLPOOL NO-FROST REFRIG/FREEZR MODEL-EHT201ZKWR5
looks like operating normally...
the fridge as it reaches it's temperature shuts the compressor off and then after a few minutes..the fridge would increase temperature again and would turn back the compressor again.
its the thermostat which is cutting on and off the compressor.
and i think it is normal. based on the temperatures that you indicated..it is cooling very well..0 F in the freezer and 40 in the refrigerator... that's good.
drcool
Nov 06, 2008 | Whirlpool Refrigerators
Fridge intermittently bangs like very loud champagne cork popping
Sometimes when fridge first starts they can sound like water dripping into hot oil or deep fryer, this is caused by liquid refrigerant returning to compressor which has hot oil in sump, this is normal and no need for alarm, unless the fridge is not keeping temperature.
Nov 04, 2008 | Refrigerators
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
182 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
