Question about Philips Magnavox 51MP392H Rear Projection Television
Bad dull color on a magnavox 55p8288a... how do I change the coolant in this tv
  • Philips Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set aftebad dull color on a - 65af323.jpgnge
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2011
Projection magnovox 46 tv , color is alittle off.. Are one or all of my bulbs bad?
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
TV set after fluid change
69189a5.pngSOLUTION
Jan 13, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My 50 in Phillips rear projection has a bad green tint and switches to a bad red tint what can I do?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 10, 2011 | Philips Magnavox 9P6034C 60" Rear...
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture faded model number is fp4620w103
This sounds like the coolant fluid needs to be changed - the coolant turns milky after awhile and you'll get a dull image.
Google TV repair world . com and look for philips/magnavox coolant replacement:
PHILLIPS CRT Coolant Replacement Kit This is the complete coolant kit for Phillips CRT rear projection televisions. Kit contains 48oz of top quality High purity optical grade coolant with complete detailed instructions produced in clear easy to understand terms with detailed photos and illustrations that takes you through the process step by step safely dischargeing the CRTs and eliminating the need for complete realigning proceedures.Restores the vibrant colors and focus issues commonly associated with coolant that needs replacement
Oct 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
We have a Magnavox Model 55P8288A Projection tv and it is showing a cloudy and light picture.. Try to adjust color and it won't adjust...It shows a foggy picture...
Replace the CRT coolant. You can get the phillips CRT coolant replacement kit at the following link. The kit contains the coolant and the CD with instructions.
http://servicemanuals.vstore.ca/
Sep 22, 2009 | Televison & Video
Philips Magnavox 55P8288A Green tinge over entire picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 09, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Red "aura" in the middle of my 55" Phillips Magnavox
  • Screen looks 3D
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
TV doesn't come on
Your SSB Module is Bad Part # PH3912725881.
Jan 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Same Problem with carloscor Philips Magnavox 55P8288A
the following link has the cd with instructions, or the coolant change kit which has the coolant and cd with instructions on the proceedure. Its listed under the repair kit section.
Jul 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
Bad Picture on a Projection TV Magnavox 55P8288A magnavox
Change the coolant inside the CRT this will restore the color and clarity to 100% on your set.
May 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
204 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
