Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Why does my Mower not turn over fast enough to start?
  • 718 Answers
Go to smalleng.com watch video on how to adjust intake and exhaust valves. Call your local repair shop for numbers.
Posted on Apr 01, 2011
My 18 ova green fields mower fast cut starter motor won't turn engine over fast enough to start it
First check connections at battery solenoid and starter.Try jumping with another battery if it works check alternator to make sure it is charging battery and if it is replace battery
Sep 09, 2017 | Fast Garden
Why is my Briggs and Stratton mower dragging? It won't turn over fast enough to start
If it is an OHV engine the valves are needing adjusting normally as the decompression system quits working causing high compression at start-up speed.
Apr 02, 2015 | Garden
Can't get exmark mower with Kawasaki motor to start
Have had this problem with the Kawasaki engines and found the starter to be bad. The old starter was turning it over but was not fast enough to start. Have also found weak battery that did the same. The first one I ran into was a FH680 Kawasaki and spent about 2 hours trying to figure it out and it came down to the starter not turning it fast enough. Put a new starter on and started at just the bump of the switch. Let me know if this helps you out
Apr 26, 2014 | Garden
Riding mower will not turn over fast enough to start. remove plug and turns over fine.
Sounds like brushes in your starter may be worn. Or dirty terminals on battery and or solenoid.
Mar 09, 2014 | Garden
Mower cranks with throttle in choke. after cranked and throttle moved to fast or any other position. The mower dies as if someone turns it off??
Ok I assume what you are trying to say is that once it starts with the choke on and you turn the choke off it dies.
This behavior usually means that the engine is leaning out. This means that it is not getting enough gas. Often if you put it back to choke fast enough it will keep running though very roughly.
The problem is the main metering jets are plugged or there is some kind of obstruction in the carburetor. This is assuming of course that the tank is full of gas and the fuel filter is clean.
Aug 17, 2013 | Craftsman 20 hp 42 in. Deck Yard Tractor
18.5 hp engine will not turn over fast enough to start. appears to be in a bind. New battery and used jumper cables. Still will not turn over fast enough to start. Appears to be firing before it...
I have seen this many times and most people think there starter or battery is the problem. 9 times out of 10 it's not. You need to check your valve clearances. On overhead valves this is not hard at all. You just have to have the proper tools and know how. You will have to call your local dealer (engine) to get your valve settings.
Jan 20, 2011 | Cub Cadet Lawn Mower Electric PTO Clutch...
Craftsman mower will start with pull but not with
When it turns over, is it somewhat sluggish (not as fast as before)? I would suspect your battery is weak, and the voltage drops so low that the engine does not spin fast enough to start. Also, without knowing what type mower this is (which model) it could be the voltage drops too low to generate spark (if equipped with an ignition module)
Whereby pull starting it, you aren't loading the voltage down with the starter, and the ignition module still works... So it starts.
Charge the battery per the owners manual. If that doesn't help, you may need a new battery, or you may have a bad connection between the battery and starter solenoid (heavy cables). If a connection has high resistance, it will drop more voltage at a given current.
Jul 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower dies
Find the fuel air mixture screw and while the mower is running turn so mower almost stops then turn them back till the moter is running smoother.Give it some throtle to see & hear how it is running
Nov 02, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
252 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
