Question about RCA Universal Remote Control
Need dvd code for my remote - RCA Universal Remote Control
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): need dvd code for my - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
SOURCE:
Tengo director tv y quiero programar el control parai dvd Capello como lo puedo programar 88/5000 I have director tv and I want to program the control for dvd Capello as I can program it
SOLVED: Capello dvd universal remote code - Fixya
www.fixya.com/support/t19858347-capello_dvd_universal_remote_code
Sep 4, 2013 - Here is the code for the dvd player 0449, 0405, 0446 code for the tv/dvd combo 0189, 0135, 0157, 0153, 0254, 0458, 0217. website to find the other codes if you need. http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf have a good day walmart shoppers. Posted on Jan 07, 2009. SOLVED: Universal remote code for my dvd player ...
23 Oct 2017
capello dvd remote Questions & Answers (with Pictures)
22 Jun 2017
remote code capello dvd Questions & Answers (with ...
6 Oct 2015
Capello DVD player lost remote codes not available ...
18 Dec 2013
More results from www.fixya.com
I need the Universal Remote Code for the Capello DVD Player, Model ...
www.askmefast.com/I_need_the_Universal_Remote_Code_for_the_Capello_DVD_Pl... You could try these codes 0670, 0695, 0873, or 1919. Usually start with pressing set up on the remote then enter each code then press enter. While entering the code the remote must be aimed to the dvd player. If those codes won`t work with the dvd player. Normally universal remotes comes with a copy of different brands ...
I have a capello dvd player with no remote but have a rca universal ...
www.askmefast.com/I_have_a_capello_dvd_player_with_no_remote_but_have_a_rc... Jump to The manual that comes w/the uni-remote usually has several codes ... - I have a Sylvania TV/DVD hd tv what code is for the DVD on the onn remote. source: I have a onn universal remote. but i have a curtis tv... no codes work. my remote controller model # is 399000? Was this answer helpful? Yes ' ...
Apr 01, 2018 | Televison & Video
Moved and lost my remote, but can't find a code in the Universal Remote booklet for this brand.
astar dvd 3100 remote code Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your astar dvd 3100 remote code question. Get free help, tips ... Ican't program the dvd to a universal ... dvd to a universal ... My VCD can play on DVD-3100 DVD player, but DVD disc can play on it. It always show "bad disc" ...
hd 3100 DVD & Blu-Ray Players Questions & Answers - Fixya
www.fixya.com > Forum > Tags > hd 3100
toshiba HD-A35 region unlock I am looking for an unlock code for the region ...nexxTech (EDP 3100) DVD Player Can't get my nexxTech (EDP 3100) DVD ... i need to find where i can buy a remote in b.c. canada i need a remote for my astar dvd ...My VCD can play on DVD-3100 DVD player, but DVD disc can play on it.
Lost Remote, Need Code For Universal Remote jx
www.hivmr.com/db/jx97xsd37ad83fd1mksxzxkf88ca3fa9
I recently moved and lost my DTV remote, I have a Phillips PM625S 7-device .....Need remote code for ASTAR tv's .... Need remote code for Sylvania Model 6719DF TV/DVD/VCR combo. ... DB:2.37:Remote Code For Vizio Vbr120 Blu-Ray Player 88 ...Would like to programme my SKY remote but can't find the code ...
Jan 18, 2016 | Astar DVD-3100 DVD Player
Have philips univerasal remote need codes for my panasonic dmr-ez28 dvd recorder
Panasonic DMR-ES30VS DVD Recorder/VCR Universal ...
www.fixya.com > ... > Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR, universal remote related issues. Getfree help ... My remote does not work anymore. what is the code for a universal remote? Thanks in ... Question about Philips DVD & Blu-Ray Players ... How do I getremote code for GE universal remote control Need remote code? How to ...
Philips Magnavox MWR20V6 DVD Recorder/VCR Remote ...
www.fixya.com > ... > Philips Magnavox MWR20V6 DVD Recorder/VCR
Dec 20, 2015 | Panasonic Televison & Video
TRYING TO PROGRAM DVD TO DIRECTV NEED DVD CODE
I can help you with your Coby DVD & DirecTV remote control.
This is a list of all the Coby DVD control codes for DIrecTV remote controls:
20778, 20852, 21086, 21107, 21165, 21177, & 21351.
Complete instructions on entering DirecTV remote control codes are here.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Code Search
DirecTV Remote Control Onscreen Setup
May 11, 2010 | Coby DVD-224 DVD Player
Remote Codes
I found the code...
In the remote codes guide, the Cyberhome DVD player is listed under "Portable DVD"...the code is 2083...worked for me, enjoy.
Dec 28, 2007 | Cyberhome CH-DVD 300 DVD Player
Universal remote code needed
If you have tried all the codes the manual has it may be the remote does not support your model. Here is a lin to a remote I think will work on ebay:
http://cgi.ebay.com/Memorex-DVD-remote-control-MVD-2022-MVD-2042_W0QQitemZ280186652283QQihZ018QQcategoryZ91388QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You also can try another universal reote brand that might support your unit. Hope this helps.
Dec 27, 2007 | Memorex MVD2027 DVD Player
I need a remote code
have the same problem. I have Chunghop Universal remote RM88E but unable to find code for ORBIT DVD player
Dec 24, 2007 | Sylvania (SRDD495) DVD Player/VCR
Need remote codes
I have a CyberHome CH-DVD-300 unit with a Dishnet remote. The remote code that worked for me is 724.
Sep 24, 2007 | Cyberhome CH-DVD 300 DVD Player
Remote control code for magnavox dvd/vcr combo
I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
Sep 07, 2007 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
35 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
