Question about OfficeMax 0M96431 Shredder
Teeth on plastic drive gear warn down - OfficeMax 0M96431 Shredder
    Genius:
  • 1,622 Answers
Hi, you the link below to get a replacement part for your teeth that has warn out.
http://www.shredderparts.com/office-max-parts-1.php
Posted on Mar 31, 2011
3 Suggested Answers
SOURCE: plastic drive gear from motor broken
I have a left over set of these plastic gears that I can send to you. The motor bracket on mine snapped. I took it apart to check. It looks unrepairable.
edbwest@aol.com
Posted on Jan 26, 2008
  • 86 Answers
SOURCE: The first neoprene (plastic) gear wheel that makes
What brand is it ? Shredder tech ( colorado) write back.
Posted on May 06, 2010
I have a ge monogram trash compactor the ram is stuck in down position, how can we raise the ram?
Start your investigation by removing the bottom plate. There should be a belt or chain going around 3 gears. Mine has 2 metal and one plastic. The 2 metal ones are on the ends of the rods that the ram runs up and down on. The plastic one is on top of a big speed reduction gear that is turned by the motor gear. Don't pinch your fingers but see if you can turn the big gear by hand. All gears should turn. If not check each gear for broken teeth, or bad bearing & races under the 2 rod gears.
Be sure to check t
he threaded hard plastic nut that drives the screw that powers the scissors up and down. This is the part that usually fails.
Nov 24, 2012 | GE Profile GCG1580LSS 15" Built-In Trash...
When o engage the starter I only hear the motor running, what is the reason?
This condition could be because it is stuck or the teeth have been damaged. Drive teeth on the Bendix come based on how many teeth are on the starter ring gear. An incorrect match can wear some teeth down.
Sep 10, 2012 | Champion Sport & Outdoor - Others
Poulan Pro riding mower won't turn right. I can
there is a plastic connector that holds the steering shaft down into the drive gear the plastic cracks and wears out then the gear jumps passed the teeth its about a $15 part
Jun 14, 2012 | Garden
Cutter roller moves up & down with a 'popping' sound. It seems as if a shaft bearing has worn out
You will have to open it up to have a look inside...favorite is that teeth go out of the plastic drive gears or a gear cracks completely...once you can see problem contact Royal at 1-800-524-0799 for parts assistance.
Nov 05, 2010 | Royal VF1700MX Shredder
I have a 1991 dodge dakota that blew out the rear end, where can i find the gear ratio for the new rear end that i need?
I will assume you are missing your id tag. You will need to remove the rear cover and count the teeth. If you have never opened a drive axle I will warn you it will most certainly stink.
Now to figure the gear ratio:
The best way is to count the teeth on the ring gear and divide by the number of teeth on the pinion gear. Or you can count the number of turns of the pinion it takes to get one full turn of the ring gear.
For example, if we divide a ring gear with 41 teeth by a pinion gear with 10 teeth we find that the gear ratio is 4.10:1 (41/10 = 4.10).
Jan 14, 2010 | 1991 Dodge Dakota
NEED A REPLACEMENT PLASTIC GEAR THAT DRIVES THE UNIT
This Shredder is an Aurora AS650C Rebranded for Walmart as Durabrand. You can call Aurora at 800-327-8508 8-5 PST and tell them that you need one of the plastic gears for the WM6X Durabrand, they know exactly what your talking about, and will offer you two gears. The one that is in contact with the drive motor is gear "A" and the Plastc reduction gear that drives the steel gears is gear "B" Hope this helps
May 26, 2009 | Office Equipment & Supplies
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Plastic drive gear from motor broken
edbwest@aol.com
Oct 31, 2007 | Cross Infoguard Shredder SX102M
OfficeMax 0M96431 Shredder Logo
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
