Question about GE Heating & Cooling
MY AIR CONDITIONER FREEZES UP - GE Heating & Cooling
  • 182 Answers
Clean filter?if so,prolly low on freon.
Posted on Aug 05, 2008
The inside unit (model E2EB-017HB) freezes.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 14, 2011 | Intertherm Heating & Cooling
Unit freezes up. Fins seem to be bent
heatman101
Aug 03, 2011 | Quasar HQ2081QH Air Conditioner
My NewAir ACP-1400/H air conditioner freezes up. I have cleaned the filter and check the air flow. Everything seems good, but it still freezes up.
Its sounds like a refrigerant leak from the factory if you just got it. Check your warranty and call the manufacturer for repairs. Unfortunately there is no simple fix.
May 17, 2011 | NewAir ACP-1400E Portable Air Conditioner
My dometic duo-therm freezes up and does not drip water. What is the problem?
Either the unit is low on charge or the fileter/coils are plugged with dirt and decreasing the air flow so that is freezes
heatman101
Mar 26, 2011 | Dometic Rooftop RV Air Conditioner
It freezes in the front by the air filter
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 10, 2010 | Fedders A6D24E7D Wall/Window Air...
Why is my air conditioner freezing up?
The most common reason for an air conditioner to freeze is a clogged evaporator coil. Check and see if the filter is clean If yes then pull the unit our of its case and use the garden hose to clean it out. If it freezes after all of these steps it likely needs a shot of refrigerant.
Jun 27, 2010 | Haier ESA306 Air Conditioner
Why does my air conditioner in my car blow out hot air? one minute, it'll cool just fine and the next minute, it blows out hot air.
Assuming you are not low on freon:
I have seen this symptom caused by too much moisture in the system too, it freezes near the metering device which kills the refrigeration effect which makes it warm up, the ice melts and it starts working until moisture builds up and freezes which kills the refrigeration effect again.
Jun 02, 2010 | Whirlwind FH-778 Air Conditioner
How can I validate the tonage of my Ruud air conditioner? The model number is M0696. The serical number is RCBA-3/65AS17
you must have very old equipment are you sure of the model and serial number it might be a 69 if the serial number is the m0696. Tom double check those numbers.
Jun 28, 2009 | Ruud Matching Split Air Conditioner
Botton of evaporator coil freezes and compressor
This is a common problem with any type air conditioner it is caused by to much humidity in the air when the unit is not big enough to Handel the cooling I would suggest getting a bigger unit, adding another unit or a dehumidifier, or setting the unit to a higher temp. then turning it down gradually to let the ice melt and take the humidity out gradually.
Jun 27, 2009 | Ambiance Designs HG002261 Portable Air...
Heating & Cooling Logo
41 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Todd B
Tom Chichester
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
