Question about Jenn-Air JED8230 Electric Cooktop
3 wires out of the wall... 4 wire hook up.connected Black, White, Green... do I bridge for the red wire? heating elements work. But No fan
    President:
  • 1,430 Answers
No the red is a hot wire, thats why you do not have full power. Check this link it shows the correct wiring Replacing an oven cord
Posted on Mar 31, 2011
Wiring for Kenmore Elite Induction Cooktop
The white one may just form an earth loop,, I recently had a ceramic plate needing cleaned so we did the whole lot, I think most hobs have 4 wires and they are numbered rather than colour coded..hope this helps
Nov 10, 2013 | Kenmore 30" Induction Cooktop Stainless...
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
Do i connect the red and black wires together
No you do not. You have a 220 system. What you do to hook it up is. In the box in the wall you should have 3 wires. 2 black and one white. Then on the cooktop you have the 3 wires 1 black, 1 red, and 1 white. You take the black from the cooktop to the black in the wall box. Take the red to the other black in the wall box. then take the whites and put them together. Now if you have a green or bare wire that is the ground. Just hook that to the wall box.
If you have any questions please ask.
May 09, 2010 | Jenn-Air JED8230 Electric Cooktop
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
JED8430BD has 3 wires no ground. Wall has 3 wires including ground
I think the white on the cooktop should be on ground.
cooktop wall
Red White
Black Black
White Ground
Sep 04, 2008 | Jenn-Air JED8430 Electric Cooktop
Burners not working but fan is
Are you sure that is the proper wire from the wall? What you are describing is a 110 volt circuit. THis cooktop should be connected with at least #10 wire and fused at 30 amps. You should have black red and at least white with possible bare ground wire. Assuming somebody used the wrong wire during original install job, you have it connected right. Please replace with heavier wire if it is not #10 Or at least make sure it is fused at no more than 20 amps if smaller wire. (You may sometimes blow circuit breaker if all burners are used on high at once) Use a volt meter and check voltage. If this is a 220 volt circuit you should have 220 volts between black and white and 110 volts from either one to bare ground wire.
Jul 02, 2008 | Jenn-Air JED8430 Electric Cooktop
Electrical hookup
no its 220 red to one 110 line blk to the other 110 line white to neutral should be a solid metel wire to take that to ground
Jan 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
150 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
