Question about Cisco Aironet 1262N Wireless Access Point 300 Mbps - IEEE 802.11n (draft) - 1 x 10/100/1000Base-T Ne... (AIRLAP1262NAK9)
How do you reset/configure a cisco 1262n access point?
SOURCE: cicso 1131ag Drops off
Meru
Posted on Mar 06, 2008
  • 8404 Answers
SOURCE: how to initially configure the access point
Should work right out of the box. Are you asking what type security you should set up?
There is password security, turn off the broadcast security, MAC address security and others.
May I suggest Network Magic to help you set up and maintain your network.
I use the paid pro version and love it.
Get it free - google Network Magic
Posted on Oct 19, 2009
  • 106 Answers
SOURCE: Access point configuration
Access is easy to configure, you just need to understand basic setup you need to do and just have to find the same options on the configuration page of any wireless access point.
Things to setup.
1. Local IP Address ( You will get default 192.168.1.1 according to your device guide, still you can set different (not recommended, if not expert) )
2. Setup WAN IP-This could be dial up connection (PPPOE) or Internet IP Address provided by your internet provider.
3. Setup Wireless access point SSID, this is what you will find when you scan for wireless connection available
4. Setup security settings. You can setup WPA or WAP to protect security. Just need to select and assign key/password which you will be asked while connecting SSID
Follow the link for exact information on how to setup your Access Point
http://www.tomsguide.com/us/asus-wl-wl330,review-233-3.html
http://support.asus.com/faq/asus-faq.aspx?no=E8D3A5FD-995C-D299-0AE3-FBF28AA04DA6&SLanguage=en-us
http://www.ddp.ru/upload/images/PDF/WL_HDD25.pdf
Hope this helps
Posted on Jun 02, 2010
SOURCE: I'm trying to configure my
Network settings on your computer
right click on lan network and properties go to ipv4 properties and use the following.
IP address 192.168.1.2
255.255.255.0
router defaut in the default gateway settings (mine was 192.168.1.245)
enter that again in the dns primary (dont worry about the secondary)
plug an ethernet cable to your wireless router and type in the default gateway.
that will get you to your logon page.
hope that helps
Posted on Jan 11, 2011
  • 3 Answers
SOURCE: How to reset password to
To reset the password if you have forgotten it, you must reset the whole thing to factory settings, which means you must reconfigure everything. This involves the mode button which is the little button to the right of the ethernet and cable lock slot, this will require a pencil/pen: 1. Disconnect the power to the access point 2.Plug the power cable back in and at the same time hold in the mode button 3.Hold the button for about 3 seconds until the light turns amber 4.Wait for it to reboot and you should be able to reconfigure like it was brand new
Posted on Mar 13, 2011
Can get router to work
The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
This resetting process works through your internet browser.
Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
Enter your user and password information from the pop up menu.
Click on the "Setup" button from the summary status page.
Select the "Cisco Services" setup option and click on "Manage System Configuration."
Click on "Reset All System Factory Defaults" to reset the router.
The Cisco Aironet 1200 will be restored to factory defaults.
http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
Cisco Acces Point series 1020 Air-AP-1020-A-KG
This is an enterprise AP and needs to run with a Cisco router.
Mar 30, 2014 | Cisco Computers & Internet
Reset Access point Cisco 1020
If your current controller can't see the AP, then the 1020 can only be reset through the Controller it was originally configured with. It doesn't have a console port, so you have to connect it to the old controller and run "clear lwapp private-config"
Mar 25, 2014 | Symbol Spectrum24 4131 Access Point...
Reset my Cisco AIR-AP1242AG-N-K9 but still can't access the control panel using a console calbe and laptop. Using Cisco Cisco as user name and password. Note when typing the password nothing appears in...
Hmmm..., I assume you are using Windows..... Try just going to the Network, see if you router shows up if so.... Click on it... It should ask for a pin type in the pin that usually can be found on the bottom of your router... If not reset to factory defaults and in your broswer type in your IP address, do not use autoconfiguration.... On all Linksys routers the default username is admin (with the password left empty) from there you can set your password and configure your router for use.... Hope this helps ;)
Jan 05, 2011 | Cisco Aironet® 1242AG (AIR-AP1242AG-N-K9)...
Reset cisco airnet 1130ag
There are 2 ways to reset the access point.
Using the MODE Button
Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
1. blank.gifOpen the access point cover
2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. blank.gifEnter the username Cisco in the User Name field.
4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. blank.gifClick System Software. The System Software screen appears.
6. blank.gifClick System Configuration. The System Configuration screen appears.
7. blank.gifClick the Reset to Defaults button.
Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
8. blank.gifAfter the access point reboots, you must reconfigure it.
Aug 13, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Jan 17, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Cisco Aironet 1262N Wireless Access Point 300 Mbps - IEEE 802.11n (draft) - 1 x 10/100/1000Base-T Ne... (AIRLAP1262NAK9) Logo
3,710 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
