Question about Toshiba Computers & Internet
Is there a tutorial on how to replace the monitor on my toshiba qosmio x300 11s laptop? thanks
    Guru:
  • 592 Answers
This is a guide how to disassemble the unit. http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-X305/laptop-disassembly-1.htm
that will get you part of the way and show you how to remove the screen and its cables. The actual replacement is easy but some liek to take the screen off the unit bezel and all.
Remove the protective plastic or rubber over the screw slots. Once you do that there will be small phillips head screws inside. remove those. Now use a plastic pry tool or be careful and use something else to sepereate the frotn bezel from the rear. Once you pop this up you need to be careful removing it completely. ust taek yoru time. after that push the screen down as parallel to the computer as you can. on the unit around the screen you will see a series of screws holding it on. remove these. Look below the screen there is a small bar like board. This is the inverter. remove the cord from the lcd to it. After you do be careful when you pull the screen up. There are going to be a cable from the motherboard to the screen. Remove this gently and you can take the screen out. Reverse for installation.
Posted on Mar 31, 2011
How to install windows xp in toshiba qosmio f30-112
If the Notebook cannot find the device driver it is looking for then use this restore disk for an easy solution.
WINDOWS IS NOT ON THIS RESTORE DISK
This restore disk will only work for use with Toshiba Qosmio F30-112. This restore disk contains every driver for the Toshiba Qosmio F30-112.
http://restore-disk.com/shop/CartAdd.asp?ID=149816
Toshiba Qosmio F30-112 XP ... windows XP restore disk is a one stop solution. The Qosmio F30-112 drivers in ... Toshiba Qosmio F30-112 XP Notebook plug and play will install ...
TOTAL: $15.92
hope this helps
Sep 12, 2012 | Toshiba Qosmio F30-112 Laptop DC Car...
Hi i have problem with toshiba qosmio g25-av513 when i power on its show clear QOSMIO monogram and then start show saverl difrent colurs lines i try with external monitor show same .pls help me to fix this...
You can try downloading the most recent video drivers from the nvidia web site and installing them.
Other than that you would probably need to contact Toshiba tech support. Based on the information you provided it sounds like your video card is having a hardware issue. It's the reason you see the same lines on both monitors.
Apr 10, 2011 | Toshiba Qosmio G25-AV513 Notebook
I own a Toshiba Qosmio G15-AV501 laptop with the vertical cyan lines problem. Every area of my monitor that should be white is instead covered with cyan and white pinstripes. The bad news is that this...
What your describing is usually a video chip problem, if you had to send it in for repair under a recall or warranty issue, and it was repaired by Toshiba, then by all means contact them and seek further repair. Or you can also politely tell them that you would like them to replace the laptop with a similar model. I have worked with Toshiba as well as many other brands, and I have found that most if not all companies will be willing to " Make it right" for the consumer.
Apr 18, 2017 | Toshiba Qosmio G15 Notebook
Pci express error
Means you network card has somehow got weged out and its halfway in, halfway out.
You would have to open up the laptop and make sure everything is pushed in.
Dec 31, 2009 | Toshiba Qosmio G25-AV513 Notebook
How to set up multiple external monitors on a laptop
Since you only have one external monitor port, you need to use a video spillter, this will allow you to connect two or more external monitors.
NOTE: This video splitter will only give you duplicated displays. Please check the link below:
http://www.kvm-switches-online.com/video-splitters.html
Thank you!
Dec 29, 2009 | Toshiba Qosmio F45-AV412 Notebook
Toshiba Qosmio X305-Q705 Laptop screen yellow
It is not a driver or video card problem. It is the monitor.
To be sure plug a full size desktop monitor into your laptops monitor jack. Every laptop has one. If the picture doesn't turn yellow that will confirm that your LCD is bad.
Aug 16, 2009 | Toshiba QOSMIO F15-AV201 Notebook
Open up a toshiba qosmio f25 av205
This site has free info and Pic to open up the laptop.
one screw is hidden under monitor cable.
look up replace video card.
Ckreuzer
Dec 26, 2008 | Toshiba Qosmio F25-AV205 Notebook
Laptop problem
Sorry, video drivers will not solve this. This is a known hardware issue. The only "apparent" fix is to send it to toshiba if under warranty or replace the motherboard yourself.
http://tais-app-p01.toshiba.com:8080/KanisaPlatform/Publishing/672/1199_f.html
May 21, 2008 | Toshiba Qosmio G25-AV513 Notebook
Computers & Internet Logo
165 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
