Xerox 6180 color laser printer - black is smearing on image side of paper. Also have a bit of smearing on the back of papaper. Was a gradual degredation, now it is really bad.
  • 82 Answers
I think it would be to blame the black cartridge has fewer pages to print, probably having lost toner waste tank full and probably dirty image transfer kit worn. replace the black cartridge(if is like i said) and clean image transfer with a clean soft cloth inside the printer and all intake of residual damage including Fuser .
Posted on Mar 31, 2011
Xerox 4620 is printing smears all over the page. I replaced the drum but it is still happening. Not sure what could cause this prblem
ask yourself this . Is the paper warm or hot when it has been printed on ?
check fuser unit .
No heat equals unbonded toner on paper equals smearing of toner on paper.
Oct 20, 2015 | Xerox Laser Printers 4620/DN Phaser 4620DN...
How do you print two sided on xerox 6180 phaser
I expect you have to put the paper in the other side up. however if you do you could spoil the first side as it will melt the wax again when it's fusing the second side!
Good Luck.
Jul 31, 2014 | Xerox Phaser 6180N Laser Printer
6180 copier color issue
A bit more information would be useful
Jun 14, 2014 | Xerox Phaser 6180N Laser Printer
Clean printheads on Xerox phaser 6180
This type of print quality defect shows up if you have loaded the wrong type of paper in your machine and didn't remember to change the paper type (plain paper, card stock, labels, etc.).
This can also happen if the paper has a high moisture content, or if the humidity in the room is too much. Also make sure the room temperature is within its normal operating range (not too hot, not too cold).
The problem you describe could also be caused by using non-Xerox toner/drum units. Compatible toners don't work very well in Xerox printers.
Aside from those problems, the only other thing would be if the Fuser Assembly is near the end of its life...it will also cause some print quality problems like you are describing.
Dec 24, 2013 | Xerox Phaser Office Equipment & Supplies
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
My Xerox Phaser 6125 smears black (!) toner, extra obvious and totalley unacceptable on double sided printed sheets. Different types of paper all show the same problem.
This would normally be the cleaning unit to blame. If in doubt go,to the Xerox.com website and investigate further.
Good luck.
Sep 24, 2013 | Xerox Phaser 6125 Laser Printer
Xerox 6180 James at Tray 1 mpt every time!
Your lower trays are programmed incorrectly. Change the size and or the paper type back to letter and plain paper
Aug 23, 2012 | Xerox Phaser 6180N Laser Printer
Color Printer Xerox Phaser 6180 Black Background Print out
Try the link below. If the toner is leaking from the cartridge return it to shop were you got it if it is damaged.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=466,E=0000000001344030351,K=1906,Sxi=11,Case=obj(1307)
Niallbt
Mar 27, 2009 | Xerox Phaser 7750DN Laser Printer
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
110 people viewed this question
jasbo
jasbo
