Question about Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
Tengo un problema de impresion a color imprime con rayas
pagebor
  • 2785 Answers
SOURCE: problema al instalar
plz post in english so that we can help you
Posted on Aug 12, 2008
MXM450
  • 62 Answers
SOURCE: sale una raya negra en la impresion
tambor
Posted on Jan 22, 2009
toris
  • 29 Answers
SOURCE: tengo un canon mp140 y me pone e4 y e5.creo che
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-12
Posted on Sep 04, 2009
pineworks
  • 4041 Answers
SOURCE: error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Posted on Jan 25, 2010
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
Hola el problema que tengo es que la impresora copia muy oscuro y en un tomo chocolate quiera saber que puedo hacer en este caso gracias
Empezando, qu? impresora tienes? Si es un Deskjet y est?s escribiendo en modo de "color", deber?as ponerlo en modo de "black". Independientemente a eso, posiblemente tienes uno de los cabezales funconando incorrectamente de tal forma que el resultante de la impresi?n en vez de "black" sale marron.
Imprime los colores b?sicos para verificar cu?l es el color que causa el problema para reemplazar el cartucho o cabezal
Apr 18, 2015 | Office Equipment & Supplies
TENGO PROBLEMA CON UNA PLASMA HITACHI 42HDT79 SOLO SE VEN RAYAS DE COLORES VERTICALES SI HAY SONIDO Y ABAJO DE LAS RAYAS SE VE LA IMAGEN
Hola que tal oye porque cuando prendo mi tele Hitachi 42hdt79 se pone en standby se escucha todo pero no se mira nada ni le puedo cambiar de canal ni subir volumen
Aug 30, 2012 | Hitachi 42HDT79 42 in. Plasma Television
Tengo una i,presora HP P4015n y ne sale un error 49.FF04 error turn off then on, como soluciono este problema?
Tengo un problema con la i hp 4014n, de repente empezo a imprimir los documentos con partes en blanco o imprime algunas partes otras no... marca error y no se puede imprimir el documento pero lo imrpime igual solo q con este problema
Sep 19, 2011 | HP LaserJet P4014n Printer
Tengo una impresora EpsomTX300f tomando fotocopias me imprime pero me produce una sombra en toda la hoja, esto me la hace muy lenta como hago para solucionar este problema. Agradesco su pronta ayuda.
Que tal.
Este problema puede ser causado por varias cosas. Entre ellas una mala configuración de los drives de la computadora, trata descargandolos desde la pagina oficial de Epson. También puede tratarse de un problema con los cartuchos algún defecto de fabrica(pequeña fuga). Si los cartuchos son rellenados, puede que no sean reconocidos de manera correcta por tu impresora.
Saludos.
Aug 28, 2011 | Office Equipment & Supplies
TENGO UNA HP 4355 Y ME MARCA UN ERRO EN CART.
Para empezar, quite el enchufe de la corrente como unos diez minutos
Si sigue tenendo el problema quite los cartuchos y los vuelva a poner.
Si todavia tiene el error limpie con algodon y alcohol la superficie del contacto de metal donde se pone el cartridge.
Si sigue non funcionando el cartridge puede ser defectuoso, intente cambiarlo, posibilmente con uno original.
Sep 06, 2008 | HP Officejet 4215 All-in-One Color Photo...
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
57 people viewed this question
old marine
old marine
