Question about Home
I am trying to make my old bathtub look better. there is an ugly ring of rust around the tub drain handle there is a round stainless steel housing that screws on the front of the tub with a knob in the center to drain water. I want to cover that rust with a stainless steel washer put in behind the housing. Or other suggestion. Also the drain plug is ugly and woould like to replace just the plug. It is a kohler put in about 1960. can I replace just the plug? there is a flat screwdriver slot in the center of if I removed that cant figure out how to remove plug.
  • 58 Answers
Normally if you can unscrew the screw from there than you should be able to pull out just the metal part and have it changed.
Posted on Mar 31, 2011
Rusty water comes out of cold water faucet
Rust is usually a sign of galvanized pipe mixed with copper pipe incorrectly.Could be the pipe nipple used for the tub spout connection to the valve.You could change it to a brass nipple might be the problem
Jun 24, 2010 | Moen 1 Handle Lever Shower Faucet With...
Resufacing an old bathtub
The answer to this depends on whether you intend to have the bath re-enamelled (vitreous enamel) or whether you intend to use one of the proprietary DIY roller paint "enamelling" systems.
If you plan to have vitreous enamel then any company doing it will not guarantee the outcome or the finish unless you have them do all of the preparation; typically they'll blast the tub back to completely bare steel/cast iron and chemically wash it afterwards. Without this there's a good chance that when the tub comes out of the kiln there will be pinholes (a.k.a. birdseyes) in the finish. If this happens after they've done the prep they'll re-blast it and start again if need be, but not if it's your fault.
But if you plan to use the DIY system then all you need is a smooth and clean base so you can hire a blaster and do the job in your own workshop. Fill any pitting left by rust before repainting the bath, lead or two part epoxy car body filler do the job just fine. DIY kits don't give a great finish but they do look far better than a tired bath with chipped/cracked vitreous enamel if you can't afford to get the job done properly.
Sep 30, 2009 | Maax URBAN 7242F FREESTANDING BATHTUB -...
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
My LG dishwasher stainless steel tub is getting an ugly residue. I have tried to clean it with a stainless steel cleaner but it doesn't help. I am also not happy with the cleaning of my dishes. I have...
If residue is a brown color it can be minerals in the water.You can buy a stainless steel cleaner, just put it in the machine and run it thru a cycle.
Use only good brand name detergent - no tablets- use rinse aid- check arms for blockages-stack dishes with soiled side facing the centre-
LG are an excellent dishwasher
Sep 11, 2009 | Dishwashers
Yellow ring around jacuzzi...
run fresh water around the jacuzzi it sounds like grease lodged around the pipes of the unit to motor , leave running for half a hour and drain again ???
Feb 04, 2009 | Home
Stainless steel is rusty/blotchy
Jenn Air makes great products, don't blame them. Your type of stainless steel is a consumer grade that has less nickel-chromium in the mix making it affordable to the consumer. The surface needs to be "pacified", DeBruce Polish will REMOVE THE RUST and PACIFY the surface. We get Debruce Polish at debrucepolish.com.
Jan 02, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Home Logo
73 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
