Question about Fujitsu Fuji FinePix F50fd Digital Camera
Cannot find either manual or disc! for my finepix f72. Quite new and cannot even take out battery to charge. Do have charger. Help please
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fujitsu Master
  • 102,366 Answers
You can download the manual from the manufacturer's web site at
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/f/finepix_f50fd_manual_01.pdf
You don't need any additional software to use the camera. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free Picasa ( http://picasa.google.com ).
Posted on Mar 31, 2011
    Scholar:
  • 37 Answers
Your Futjitsu FinePix is similar to the Nikon CoolPix. The battery is located on the BOTTOM of the camera, under a delicate plate which snaps out. Be careful when you try to move the sliding plate; pull it carefully by putting thumb pressure on it and push TOWARD yourself with the plate opening turned away from you. You will see two slots; a battery slot and a memory card slot. Check to see that the battery is IN the slot, then close it. Use your cable adapter to charge the battery by inserting the SMALL end into the adapter port and the other end should be a charger/wall outlet plug. Have fun, I have taken great pictures with the Nikon CoolPix.
Sciencewoman
I lost my fujifilm finepix jx 400 battary charger and i want to use my usb cable to charge it is it possible i plug it but it seems doesn't charge
The JX-400 is a camera, not a battery charger. Connecting it to a computer's USB port simply drains the battery faster since the camera has to expend juice communicating with the computer (even if only to say it has nothing to say).
One source for a battery charger is http://www.overstock.com/Electronics/BasAcc-Battery-Charger-Set-for-NP-45-Fuji-FinePix-S610-J110-J150W/7124327/product.html?searchidx=3
Feb 15, 2014 | Cameras
Battery wont charge
As in the first part of the manual is explained, when you have inserted the battery correct and you then plug in the charger, the charger light should go on. When the light is out, the battery is charged. When the light blinks, your battery is fault.
When the light does not go on, when you plug it in a power outlet, the battery is not inserted correct, or the contacts are dirty.
If you want to clean the contacts, please only use a dry cloth. Never us a sharp tool. It would damage the contacts bend repair.
Even when you plug in the charger, with a fully loaded battery, the light should go on for only a few moments.
Make sure the power outlet works normally. and the power cable is not defect.
Dec 29, 2013 | Fuji FinePix F460 Digital Camera
My niece owns a finepix fujifilm camera that will not come on even after she charges her battery. She thinks it maybe the charger thats causing the problem. What other ways can she charge her camera if the...
Non..You will have to replace the charger or at leat have it checked. Find someone with a multimeter ( electronics shop) they will surely test it for you free.
If it is not the charger then try cleaning the battery terminals inside the camera to ensure good contact or even a NEW battery as this one may have reached its life expectancy
Please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | Fuji FinePix S7000 Digital Camera
How do you charge the battery on a fuji finepix z digital camera
The battery does not charge via USB.
Place the battery into the charger, then plug the charger into a wall socket.
Refer to the section titled "Charging the Battery" in the manual.
Jan 02, 2010 | Cameras
Digital camera not working
Battery must be ok. Check the switch contacts. Battery contacts.
Sep 11, 2009 | Fuji FinePix F401 Digital Camera
Fuji Finepix F710 not charging
The problem of yours,is the battery is need to change a new one.That's is the symptom of the battery is near to "run out"it cannot stored the charge,it will automatically discharge,when you pull out the charger connection...
Hope this may help;
DON'T FORGET TO RATE;
Regards,
VOTIT
Jul 29, 2008 | Fuji FinePix F710 Digital Camera
Fuji FinePix A400
Take the batteries out and clean the contacts
Those at the bottom of the battery compartment you can clean with the eraser at the end of a pencil
do the same with the lid.
Make sure the batteries are fresh/charged
When you close and lock the compartment lid squeeze it shut then turn on- it may be a contact problem.
If this fails then it will be a repair shop job
Dec 07, 2007 | Fuji FinePix S3100 Digital Camera
Fuji finepix a330 digital camera says "low battery"
To help rule out if the battery, camera, or even your charger I would suggest to first clean all the contacts. This can be done with some rubbing alchol and a q-tip, make sure you get the contacts in the camera, directly on the battery, and your charger. Wipe off any excess alchol and let it sit for a minute or two so the alchol can evaporate. Give the battery a good charge and see what happens. Where did you purchase that replament battery? If what was under 10bucks I would suspect it's the battery, there are a ton of crap battery's hitting the market, always stick with name brand. Another possibility is that the charger could be sending the wrong voltage to the battery causing inproper charging, or even the chargers power cord could be sending the wrong voltage to the charger. Anyway I'm done rambling, It's 12:15am and I have a 70hour week starting in 6 hours so i'm outta here. Hope this helps. And here's a link to your manual if you need it: http://www.fujifilmusa.com/JSP/fuji/epartners/bin/A330A340Manual_1.pdf L8R Good Luck
Sep 16, 2007 | Fuji FinePix A330 Digital Camera
Rechargeable Battery won't charge
I think this is a general Fuji design fault in the camera circuitry. I have an older F455 which has exactly the same problem and I did the same - bought new batteries only to discover that didn't help. The only solution is to spend even more money for a stand alone battery charger.
Sep 07, 2006 | Fuji FinePix A340 Digital Camera
Fujitsu Fuji FinePix F50fd Digital Camera Logo
90 people viewed this question
Top Fujitsu Cameras Experts
Jerry Greenberg
Jerry Greenberg
Robin Hill
Robin Hill
Are you a Fujitsu Camera Expert? Answer questions, earn points and help others
