Question about Panasonic KX-T7730 Corded Phone
Hi , i have one T-7730 . is there any way that i can connect it directly my phone line ? what kind of setting needed ? cheers
  • Panasonic Master
  • 2,460 Answers
No. None. However, you can search E-Pay and find a compatible KX-T series system for less than $100.
Carl
Posted on Apr 01, 2011
Can I connect Panasonic KX-T7730 to the normal line as other phone are connected?
What? A 7730 is a Panasonic system phone that connects to one of about 18 different Panasonic phone systems. You can connect a single line set in parallel with the PT if you tell it so in software.
Carl
Sep 05, 2011 | Panasonic KX-T7730 Corded Phone
Hi , i have a problem with my KX-T7730 : in brief , when i press the line access code which is the " 9 key" , it gives me wrong CO . so i want to change the program and set it to my desire CO...
So many options. Why are you dialing "9" for an outside line? You can just press a button assigned to the line you want.
Since a 7730 works on up to 18 different Pana systems, there's no telling what you have, but you can assign a specific line to a button, a group to a button, program the system to not pick vacant lines, or dial the direct line 8x or 8xx access code. There's an outside chance that ARS (automatic route selection) is enabled and the "9" doesn't even give you an outside line in the first place.
Which is yours?
Carl
Aug 28, 2011 | Panasonic KX-T7730 Corded Phone
I have panasonic kx-t7730 phone .i have 3 lines in same number from my service provider .2 lines are already assinged its working fine my 3rd line is not working when i try to press the 3rd button its...
Your 7730 is just a phone. The programming is done to the SYSTEM that the 7730 plug into, from either a maintenance program on a PC or extension 101. There will be a programming manual (PM) for the particular system, be it a TA-624, 824 TAW or different system. In system programming, you turn the lines on in system program 400 and adjust the ringing in programs 407-409 (TA codes). You also have to plug the 3rd line into the CO3 port on the cabinet.
Carl
Apr 03, 2011 | Panasonic KX-T7730 Corded Phone
I have use llinksys PAP2T togather with Panasonic KX-T7730c. does it possible?
Gather what? A PAP2T is a 2-port FXS box. A 7730 is a phone that works on a Panasonic Key Service Unit. You can plug the CO lines of a KSU into the PAP box and the 7730 into the KSU and get dial tone on whatever line you used on the PAP if that's what you're asking.
Carl
Mar 24, 2011 | Panasonic KX-T7730 Corded Phone
Hi i want connect a 7730 phone call to fxs port dvg 5008 .. what settings should i do?
A 7730 is a Panasonic system phone. It requires a Pana system to operate, so I'm confused as to what you're asking. If the phone call is INTO a 7730 phone and you want it to a phone on the DVG, you will need something to transport it, like an FXO circuit tied to the Panasonic's station ports. If the phone call is FROM the DVG and you want to answer it on a 7730, you plug the FXS ports into the CO ports of the Pana Key Service Unit that the 7730 is plugged into.
Hope it helps.
Carl
Mar 13, 2011 | Panasonic KX-T7730 Corded Phone
Hi I have a panasonic KX-T7730 and I need to connect it to my linksys PAP2T Device. but I haven't Voice Over It. can I use this device with KX-T7730?
The 7730 is a Panasonic Analog System phone. It plugs into a Key Service Unit and the line port plugs into the PAP2T device. Model numbers like KXT-A624/824 are examples.
Carl
Feb 18, 2011 | Panasonic KX-T7730 Corded Phone
Hi i bought my new panasonic KX-T7730 but when i bring it home and try to make a call its not working there is no dial tone can u plz help me
Did you just buy the 7730 or do you have other ones in your house? Since a 7730 is designed to plug into a Panasonic SYSTEM, you'll be waiting a long time to make it work if you're plugging it into a regular phone line :-)
Carl
Sep 28, 2010 | Panasonic KX-T7730 Corded Phone
Need to connect phone and fax machine to one phone jack
You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:http://www.trianglecables.com/tellinsplitl.html
A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
Mar 29, 2009 | RCA 25201RE1 Corded Phone
Music outside the phone
we have kx t 7730 phone and we want to listen to music system outside the phone when not in use what shoul we do please guide
May 14, 2008 | Panasonic KX-T7730 Corded Phone
Phone settings
I HAVE A PANASONIC KX-T 7730 WITH 3 LINES
I WOULD LIKE TO KNOW HOW TO SET THE RING..BCOZ WHILE A INCOMING CALL COMES, THE PHONE NOT RINGS ONLY THE LIGHT BLINKS... WAT TO DO?
Feb 27, 2008 | Lands Phones
Panasonic KX-T7730 Corded Phone Logo
41 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
