Question about Xerox 8830 Copier
When exporting document to the 8830 printer, displays Prossessing to no end. Can you help
    Genius:
  • 1,622 Answers
Hi, issues like this you will need to reset the printer and restart the system your trying to export and it will work properly.
But make sure the system has not been overworked,cause it will need to cool down for it to work normal again.
Sometimes when light fluctuate, it can also affect.The only solution is to reset the printer and restart the system.
Good luck.
Posted on Mar 31, 2011
8830 Idle Message
Try to reinstall the driver. You can get the latest from the link below:
http://www.nodevice.com/driver/xerox-8830-printer/get126620.html
Sep 23, 2013 | Xerox Office Equipment & Supplies
Drivers for copier and scanner xerox 8830
Hi
You can download 8830 drivers from http://www.xerox.com/digital-printing/large-format-printers/enus.html
you need to check the type of controller that is fitted to printer.
Look on the back at box where connections are terminated.
label should have (F5Y or CNG - N5T - HFT and others select which is fitted and operating system, other support documents are also found here.
Jan 24, 2011 | Xerox 8830 Copier
My plotter isn't giving me a preview of my documents that I have scanned
u have to press the sample button on scanner before scanning the document
Apr 30, 2010 | Xerox 8830 Copier
Xerox 8830DDS
clean glass of scanner and document guide of scannerif problem not solved u need to clean full optics of scanner
Mar 03, 2010 | Xerox 8830 Copier
I have a Xerox 8830, that is getting a LL43 error
An LL43 is a fuser temperature error.
When you first turn on the printer it should display printer warming up and after a little while display the LL43. If the fuser is still cold then you probably blew the thermal fuse and it will need to be replaced.
Oct 01, 2009 | Xerox 8830 Copier
Manual Required
Hi Steve,
There are many different Xerox 8830, depending on the serial number instructions are also different.
Click here, select the one with first 3 letters of your serial number and download documentation (click on documentation on the right below selected model).
For example blow serial number CNG support links:
Support | Drivers & Downloads | Documentation
Apr 09, 2009 | Xerox 8830 Copier
I cant export a pdf from quarkxpress 6.0 Have tried everything. Its telling me to go to postscript printer??? I have made a postscribt and it does nothing. HELP
you need Adobe Acrobat Professional or Adobe Indesign in order to export or convert your documents to PDF format. There are several ways to do it, you can even use Adobe PDF printer and create PDF versions of anything you print.
Dec 29, 2008 | Computers & Internet
X8830
check to see if the fuser is turning on and heating up.
Feb 22, 2008 | Xerox 8830 Copier
14 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
