Question about Ricoh Office Equipment & Supplies
Code sc548 - Ricoh Office Equipment & Supplies
  • santosj27
    santosj27 Mar 31, 2011
    What model???
    Try to give more info so i can help you
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
Fuser unit not set properly and reset machine yellow +107 and hold on red cancel 5times and please vote
Posted on Mar 31, 2011
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
Ricoh copier 4022 sc542 sc548 error codes after changing with photo conductor unit type 1027,
If I'm not mistaken, that type of photoconductor is not compatible with your particular model of machine. The SC542 and SC548 errors are related to the fuser unit. It is not warming up correctly. It could be that it needs replacement thermostats or thermisters. It's possible that the incompatible drum unit has created this problem.
Mar 11, 2011 | Office Equipment & Supplies
Gestetner dsm645 error code sc548 solutions of free
SC548 is fuser belt rotation error, check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion, I think they have been modified, but I don't have the part number, sorry. Allso check the firmware is up to date.
Feb 19, 2011 | Gestetner DSm645 Digital Imaging System
What is error code SC548 on RICOH Aficio 2035/2045 machine. Functional problem within the copier. How do i reset the copier to operate normal?
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Jul 19, 2010 | Ricoh Aficio 2035 Copier
I have problem with my copier aficio 450,sc548 appear,please help me solve this error
SC548 is a fusing unit installation error. The machine can not detect the fusing unit for some reason. Did you have the fusing unit out of the machine? Like to remove a paper jam? In case you do not know the fusing unit is the part that gets hot. Located right before where the paper exits the copier. It comes out the front of the machine when you have the front door open. If the front door is open it is in the upper right corner and should have a blue knob on it. Make sure this unit is all the way in. You also may have a wiring or connector issue causing this as well.
You will have to enter the service mode to reset this code.
CAUTION: Do NOT mess with this service mode in any way other than the specific function I give you. Doing so could result in damage to your machine!
Enter SP (service mode) by pressing yellow C button, then press 1 0 7 on numeric keypad and then hold down the orange C button, display will change and then from the menu select "copy SP" then type in 5801 and press #, then press "execute". Turn power off and back on. If the code is gone and the machine works then your fine. If it comes back you will need to call a servicing company and have them repair the machine.
Good Luck and Thank You for using Fixya.
May 15, 2010 | Ricoh Aficio 450 Copier
Error code SC548 wont let me do anything.
please follow the instruction and you will reset the copier:
press the follow keys in order:
1. press the yellow key[c] (clear)
2. press 1-0-7 on the number pad
3.press and hold it pressed the red key [c] (stop)
4.When on the screen will appear other menu different from the usual turn off the machine from the main switch (the red switch) and then turn it on after 5 seconds.
Please answer do this is helpful for we to know if is needed some more information.(if this was not helpful you will need to write the machine model number)
Jan 22, 2010 | Office Equipment & Supplies
What does Service code SC548 on a Lanier LD435c stand for
AMCAP VIDEO CAPTURE WILL NOT FUNCTIONPROPERLY
Aug 16, 2009 | Lanier UNKNOWN
Error code sc548
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps.
Jul 08, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Jan 07, 2009 | Ricoh Aficio 450 Copier
Service Call SC548
fuser problem . danger . call tech
Dec 18, 2008 | Ricoh Aficio SP C811DN-DL Printer
183 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
