Question about Toshiba E-STUDIO 550 Copier
Double imaging on toshiba 550 what is the most probable cause?
  • 132 Answers
There could be two main reasons for double imaging
1) contaminated upper hot roller {replace}
2) worn drum cleaning blade {replace}
hope that has narrowed down your problem
Posted on Mar 31, 2011
How do i fix my toshiba studio 202s,double image result
If you have replaced all that, check your drum cleaning blade and your erase lamps, these two items will contribute for Ghost images "double image". The erase lamps disperse the electrical charge so the blade can scrap the toner off the drum.
Dec 10, 2014 | Toshiba Office Equipment & Supplies
Double image on the first copy only
try to reset your printer. Turn off, remove the power supply from the socket leave it for 30 mins and turn it on again. try one copy at a time
Sep 21, 2007 | Office Equipment & Supplies
Double image,what to do???
If it's picture that's giving a double image from your terrestrial aerial it's called ghosting , you need to move your antenna it's caused by signal reflection and usually happens when your in a strong signal area.
Oct 18, 2014 | Toshiba 40RL858 40 inch led hdtv smart tv...
Toshiba e 350 alway stick letter on paper although my rules is well
You may need a new drum cleaning blade or a new upper fixing roller. Both would cause a double image of sorts.... Good Luck
Jan 26, 2013 | Toshiba Office Equipment & Supplies
Toshiba LCD TV: Double image (right side) on power on
HEllo,
Did you find a solution to your problem?
Thanks
May 21, 2010 | Toshiba Televison & Video
C46 appeared on my toshiba e-studio 550 copier
C46 indicates Abnormal pressure roller thermistor during a ready state.
Perform following inspection:
1.. Clear the status counter.
Change the current status counter value (08-400) “3” or “8” to “0”.
If happen again, perform following inspection:
1. Check the pressure roller thermistor.
(1) Check if the connector is not disconnected.
(2) Check if the pressure roller thermistor closely touches the surface of the pressure roller.
(3) Check if the harness of the pressure roller thermistor is not open-circuited.
2. Check the LGC board.
(1) Check if the connector J334 is not disconnected.
(2) Check if the conductor pattern on the LGC board is not short- or open-circuited.
(3) Replace the LGC board.
Mar 05, 2009 | Toshiba E-STUDIO 550 Copier
My toshiba 42pw33p television show double image
If the convergence controls don't fix the issue then the convergence circuitry is most likely faulty. A Toshiba repair center will be able to get you an estimate for repair.
Oct 31, 2008 | Televison & Video
Double imaging
The Toshiba 55H70 is a standard rear projection set. It does not have a "lamp", it has 3 picture tubes. When the colors suddenly do not line up on the screen, it means that one of your convergence output IC's has burned out and needs to be replaced. This is very common on those sets. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The IC's should be replaced and the convergence circuits realigned by a qualified tech familiar with Toshiba projection sets.
Sep 11, 2007 | Toshiba 55H70 55" Rear Projection...
95 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
