Question about Apple iPhone 3G
I want to transmit out of band on my ft 60 or my vx170
  • bossman5665 Aug 05, 2008
    I want to transmit out of band on my yaesu ft 60 or my vx170
Sorry wrong Group
Posted on Aug 05, 2008
I am getting a "Err" message when trying to transmit
Almost always a programming issue. Somehow, the transmit frequency is not enabled or programmed correctly. Always include all the zeros when programming these. The decimal point is critical also.
May 24, 2016 | Yaesu Radio Communications
No transmit or receive
That unit has issues with bad solder joints after a time. The front end on that band and all boards for general purposes should be carefully inspected for cold and cracked solder joints.
Feb 19, 2014 | Yaesu FT-736R
Error message ft-530
is the radio in duplex (offset transmit freq)if keying takes radio out of band it would show err,select simplex ie transmit/recieve same freq
Dec 19, 2013 | Yaesu Radio Communications
Icom IC-7200 transmit problem on 1600.000 kHz to 1999.999 kHz
If the radio is made to be sold only in the US then the phase lock loop is disabled when your are trying to transmit out of the US band edges. Try looking up a MARS circuit mod for this model and it amounts to only clipping one end of a diode to enable the transmitter on all frequencies.
Nov 12, 2017 | Icom Radio Communications
Will not receive and transmit on 15mtrs and 17mtrs
Hi Seamus,
Is this only on those bands, not an issue with other bands?
If so, then your radio may not be fitted with the correct frequencies to transmit on those bands, they are after all allocated in part to the Amateur operators, which requires licensing to operate.
The fact you can't Tx/Rx, indicates this to be the issue.
I can't help you if you are not a licensed HAM Operator, sorry...
Enjoy the other bands available for your radio.
Cheers,
Peter
May 06, 2012 | Yaesu FT-1000MP Owners Manual
Yaesu FT-100D transmit problem
has it been opened up to talk on
Dec 17, 2009 | Radio Communications
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
PPT works in the lower bands (under 148 Mhz) but not 156 range
Your radio has not been modified to transmit outside of the amateur bands.
Jun 07, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-29...
Yeasu FT 897D
I suspect that the extended transmit will really allow you TX on 2 Meter from 136-174 or thereabouts even with modifications.
At any rate, Air Bands are amplitude modulated, have you tried switching mode to "AM" when operating 116-136MHz??
Would you post back please on how the modification (extended transmit) was done; software programming of the EEPROM or jumpers (JP1001-1009).
Good luck and kind regards.
Nov 22, 2007 | Radio Communications
Apple iPhone 3G Logo
21 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
