Question about HP LaserJet 9050 Printer
Hp LJ 9050 is printer lines across the pages.. how get i fix this issue
    Scholar:
  • 37 Answers
The printer probably has one of two problems; either your toner cartridge needs to be cleaned according to the printer's cleaning program, or it is nearly out of toner. A third issue may be that the cartridge needs to have its alignment adjusted. If so, you will see fuzzy, out of focus lines. If you will try to print a piece of graph paper, (available on most spreadsheet programs,) you will be able to tell if there are a.) fuzzy lines or crooked lines, meaning your printer needs to be aligned; b.) incomplete lines or faint lines, meaning your cartridge is nearly out of toner, or; c.) smudged or incorrectly colored lines; meaning your cartridge needs to go through a cleaning cycle.
Posted on Mar 31, 2011
  • 85 Answers
This is normally a toner problem. Try swapping toners out and try again. If not you might have a buildup of toner on a roller in there somewhere. The exception is if you are scanning and printing where you might have some goop on the glass that needs to be cleaned off.
Toner lines are being found on the drum why does lines repeat down the pages,and being found on the drum on a hp 9050
It can be caused by a bad toner cartridge. In the cartridge the are more components able to create horizontal lines. Try with another cartridge. It can be also a simptom of a broken tooth gear somewhere in the drive section or transfer belt unit. You must do some more investigation.
May 27, 2014 | HP LaserJet 9050 Printer
HP 9050 with smeared or Ghosted print on the leading edge
Your printer might have dust on the hexagonal mirror and other optical components inside the LSU (Laser System Unit). If the printer it's dirty inside, all that dust flows and lay down on components. In course of time, it reaches the optical components and generates a "gradient wiped out" image from left to right as you are looking at the printed page. This problem is common on laser printers. On colour printers, you may find that only one or more colors have this gradient wiped out. Because they have separate Laser System Units.
May 08, 2014 | HP LaserJet 9050 Printer
Hp laserjet 9050 prints blank pages
have you remove the sealing tape from toner
Mar 06, 2014 | HP LaserJet 9050 Printer
Hp 9050n paper jam 13.32
check the censor 1, pick up 2,in fixing these should the spring tentioned
Feb 18, 2013 | HEWLETT-PACKARD HEWLETT PACKARD : HP 8-bin...
Primary charging roller problem for HP LJ 3005dn
How long have you had this printer for. To solve the problem you have to buy new roller for the printer
Jul 26, 2010 | HP LaserJet 1320 Printer
How to refill toner or replace drum?
Most of these cartridges come as a refurbished cartridge. They cost about $109 US. Toner would be as much or more (but two fills) if you can find a supplier. A cartridge is about 30,000 pages so it is an EXCELLENT buy. I use laser for this very reason. Bought any 1000 page inkjet refills lately at $75?
Mar 20, 2010 | Office Equipment & Supplies
Hp LJ 4345 mfp vertical line down printed copies
Dirt.
Open the ADF, the top of the scanner/copier.
The ADF glass is the thin strip of glass on the left. Damp cloth with windex or any glass cleaner. Scrub the strip of glass.
Dec 04, 2009 | HP LaserJet 2840 Printer
Not fusing
Make sure the two blue levers are in the down position on the fuser. If the problem persist try another fuser .
Apr 03, 2009 | HP LaserJet 9050 Printer
Lines across printed page on photos
Change the paper type and paper size and that should resolve the issue.
Regrads,  raj_p5983
Jan 05, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP LaserJet 9050 Printer Logo
416 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
