Question about Compaq Presario 700 470024-192 Notebook
When i press the wireless button it says WLAN disabled and it also says ethernet driver not found
  • 62 Answers
Go to device manager by right clicking my computer (computer for windows vista and 7) > click on manage > click on device manager > expand network adapters
check if any of the sub items under network adapter has a red x ( if it does right click then choose enable)
if you have ethernet driver with a exclamation point or question mark you will need to reinstall the drivers.
you can download the drivers for network and ethernet this website:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?locale=en_US&taskId=135&prodSeriesId=96403&prodTypeId=321957&pnameOID=99935
Posted on Mar 31, 2011
My print server cannot be reset to the factory default for some reason. I have tried holding the reset button for 10 secs, but without luck.
I have some devices where I have to hold the reset for 20 seconds. So try holding it longer. And make sure the print server is powered up when you do it.
Feb 17, 2016 | Belkin (F1UP0001) Print Server
Intellinet wireless adapter malfunction
Wireless Zero Configuration (WZC) was introduced with Windows XP, it is also known as WLAN AutoConfig in Windows 7 and Vista. It is is a wireless connection management utility which dynamically selects a wireless network to connect to based on a user's preferences and various default settings. or most users the Windows Wireless Zero Utility is all that is needed to manage your wireless connections.
You can configure WZC as follows:
  1. Type services.msc in "run" and enter.
  2. Select wireless zero configuration from the list which appears in the next window.
  3. Double click on that option , and choose to Start or Stop the Wireless Zero service.
Here are steps to use Wireless Zero Configuration/WLAN AutoConfig in Windows 7:
  1. Click the Windows logo button
  2. Type services in the Start Menu's Search box and press Enter. Scroll to the bottom of the list and locate WLAN AutoConfig'. Double-click WLAN AutoConfig to open its Properties window.
  3. Click the General tab of WLAN AutoConfig service. Click the Startup type drop-down menu and click Automatic to have the service started automatically when the operating system loads. Click the Start button. Click Apply and then OK. Close the Services console window.
  4. Click the Windows logo button. Type cmd in the Search box and press Enter. In the Command Prompt window, type netsh wlan show settings and press Enter. Look at the last line of the Wireless LAN Settings entry to see if the message Auto configuration logic is enabled on interface or Auto configuration logic is disabled on interface appears. If the entry notes that it is disabled, type, set autoconfig enabled=yes interface=Interface Name and press Enter. Close the Command Prompt window.
Nov 25, 2011 | INTELLINET Wireless 150N USB Adapter...
Hi i have a u135 and it hasbuilt in blue tooth but i donot know how to activate could u help
Not sure if this will work for your model but its worth a try. Copied from MSI support faq website
You have to press the WLAN button located right next to the power button in order to enable/disable the Bluetooth function. Press WLAN button once, Enable WLAN. Press WLAN button twice, Enable Bluetooth. Press WLAN button thrice, Enable both WLAN and Bluetooth. Press WLAN button four times, Disable both WLAN and Bluetooth.
Aug 26, 2010 | MSI U100-422CA Notebook
Wireless button showing amber, but wont change when pressed
WIRELESS NETWORK BUTTON FIX FROM RED TO BLUE. 1. Press wireless button. 2. left click the dialog box in the bottom right corner it will prob say wireless disabled etc. 3. HP wireless assist box should open if so its working and you should click on properties. 4. check all unchecked boxes and press apply or ok etc.5 you should now see in the top right corner of the HP wireless assist box an option to turn on wifi press it. 6. Try the wifi button it should work! If not sorry it did for me.
Apr 15, 2010 | Compaq Presario CQ60-220US PC Laptop
Cant get my wireless connection to work not sure
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
If this does not work, check if the driver is installed in your computer by going to the device manager. check under network adapters. If the driver is installed, uninstall the current driver and restart the computer.
If the issue still persists, you may download the driver update at the msi website: http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474. Just make sure the driver you're downloading is compatible with yoru operating system
Apr 01, 2010 | MSI Wind U100-030US Laptop
Enable WLAN
Press Fn and F5
May 19, 2009 | Computers & Internet
Problem on startup with laptop combining internal ethernet and WLAN as if there is only one network connection I am trying to fix my mother's Acer Aspire 3680. It has 1GB of RAM, running XP Home SP3. It...
Sounds like the problem may be related to the power management of the internal ethernet card.
You need to check these settings in the Acer ePower Management software (usually installed with the laptop).
E.g. If you the laptop is not charging then you will not be able to see or change any settings on the internal ethernet card.
If you do not have the Acer ePower Manager installed then you can download it here;
http://acer-epower-management.software.informer.com/
Thanks
C
Apr 04, 2009 | Acer Aspire 3680 Laptop
Can not connect to internet using wireless
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
Jan 16, 2009 | Dell Inspiron 1200 Notebook
Can't get it to connect to wireless
From User manual you can download from HERE:
1) activate your WLAN :
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function recurrently.
2) Check if "Wireless LAN LED indicator glows green when Wireless LAN function is enabled."
3 ) Use Windows to configure your Wlan.
Let me know if you need more help.
Dec 29, 2008 | MSI Wind UmNotebook
Wlan disabled
If you have vista click the start button and in the start search type "hp wireless assistant". It should show up in your list while you type it. Click on it. Once the assistant box shows up, click on "properties". A "settings" box should show up. The main one you need here is "independant controls for installed wireless device". Check that box. The other ones are icons and indicators that you can check at your discretion. If in doubt, check them all. Hit the "apply" button. Then in the upper right hand side of the box hit the button that says "turn on". This should activate the device and if you have a light up indicator on your computer, it should change color or light up. That should do it. Kind of weird how it gets to that point.
Feb 26, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
