Question about Panasonic TC-32LX85 LCD TV
My t.v. has volume issues. Volume between channels and also within one channel (while viewing) not even. Happened when connected to basic cable and now when connected to just an antenna for reception. Is this fixable or should I buy this product to resolve: Terk VR1 Automatic TV Volume Controller? (looks like it would be a 2-fer purchase: take care of the loud commercials as well)!! THANKS!
  • 28 Answers
It is fixable the sound may depend upon the channels also but the antenne might not beeing catching signals properly so by changing the face of antenna u can remove this problem
Posted on Mar 31, 2011
  • pzsawchuk Apr 01, 2011
    since I had the same issue when t.v. hooked up to cable, that would rule out antenna as the problem, right? Now the t.v. on a powered indoor antenna. Before t.v. on cable service. Same volume issue either way.....
How can I change to channel 3 to view cable?
The TV has no manual channel change buttons on it? I have never seen this on any TV ever.
Mar 19, 2016 | Sylvania 6513DF 13" TV/DVD
My buttonson my tv arec all volume and my channel is stuck on a setting and i cant get any channels.will a vcr fix the problem? will it put my tv back to hdmi?
If using cable you may be able to route signal to rear audio and video inputs--doubt a vcr will help.
disconnect power from set and or a box if used--wait several minutes and power up again--HDMI can cause issues and does not like connections being made if units are on.
Dec 03, 2012 | Televison & Video
Interment or no volume on certain channels.
make sure set not set to sap mode as this can blank audio on certain channels
Sep 03, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Channel 2, 3, 4, and five do not have volume the rest of the channels have volume.
If only tuner channels 2,3,4,5 have no audio and the rest of the tuner channels do have audio then it should be a issue with the source and not a tv issue. The tuner would output the audio from the tuner for all channels. You may wish to check with the cable provider to have them check the broadcast.
Mar 08, 2011 | Panasonic TH-42PWD4U Television
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Have no volume on only one channel on Panasonic TH-42PX60U
Try the SAP - same thing happened to me and had to cycle through the audio tracks to get audio back on for that one channel. Good Luck!!!
May 12, 2009 | Panasonic TH-42PX60U Television
Low volume on some channels
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Mar 14, 2009 | Element Electronics FLX3711B 37 in. LCD TV
Sound cuts out
This sounds to me as an issue not with your AVR but with your cable unit. I have seen this where there is a sample rate issue with the cable boxes. I would try to get another cable box, and see if the issue persists.
Gary
Aug 28, 2008 | Denon AVR-2803 Receiver
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Insignia 32 inch LCD TV: Can not change Channel or Volume !
I have one in my shop with the same problem. Power is the only function that works. I repaired the power supply six monts ago. Now it looks like a bad digital processor board which is non-repairable. I can't believe what's happened to the tv business. Absolutely disgusting!
Oct 12, 2007 | Insignia IS-LCDTV32 32 in. Television
Panasonic TC-32LX85 LCD TV Logo
110 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
