Question about Kenmore 62602 Electric Dryer
I have kenmore he2 dryer. it works fine except stopped heating. how long should heating element last? what else should i check?
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][
\[0-
Posted on Aug 13, 2011
Dryer will not heat when using any of the heating cycles.
first check element, then is it isnt broken check safety fuse on element assembly for continuity theres an other termal fuse right of the fan assembly all accesible with the front panel off
Feb 22, 2015 | Kenmore Ap4327152 Motor Control Board for...
My he2 dryer is not heating, what should I check first?
If it's electric, you have a bad heating element, probably need to be replace, it's the same as a hot water heater
Nov 15, 2014 | Kenmore 6.7 cu. ft. Electric Dryer
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
My kenmore HE2 is not drying clothes. It turn s on and spins clothes but does not have heat. It is an all electic front loading dryer
If the dryer is not heating at all the three things that you want to check are going to be the heating element, the high limit thermostat and the thermostat. The high limit and the normal thermostat are going to be located on the heating element itself. All of these can checked with a volt meter set to check continuity. To access these depends on if the dryer has a two piece front or a solid front.If solid, Then you will just remove the back of the dryer and the heating element and thermostats will be located on the right hand side as your facing it, If a two piece, you'll need to remove the kick plate and the parts will be located on the right side once again. Just remember to unplug the machine , 220v hurts, trust me.
Aug 31, 2012 | Kenmore Dryers
Stop work and is showing a code f 05
Water temperature sensor error
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Dec 14, 2010 | Kenmore HE2 Plus Front Load Washer
Electric Kenmore dryer warms air but not hot Machine is front loading HE2
Hello there:
Please try each of these solutions i will provide below ok?
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct INSIDE the back cover panel.
The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Sep 26, 2010 | Kenmore Dryers
Heating element went bad in whirlpool dryer replaced it and worked fine for about 10 minutes then it stopped heating. took element back off and it looks fine help me plz
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 11, 2010 | Kenmore 84152 Electric Dryer
Older kenmore dryer works fine but stopped heating
Most likely causes are:
- one of several thermal fuses/thermostat
- broken heating element
May 02, 2009 | Kenmore 64742 Electric Dryer
Dryer will not heat
Have a certified electrician check your outlet. The dryer requires 220VAC for the heating elements to work. If this is ok, check the heating elements it may be broken.If this is ok, check the high and low limit switches, this could be defective.
Apr 04, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore 62602 Electric Dryer Logo
266 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
